Is the furnace vent on the ATC on the drivers side? Is the propane compartment still on the side? If so, where is it located - middle of the camper or nearer the back?
ATC Furnace Vent & Propane
Started by
DirtyDog
, Sep 14 2010 04:32 AM
7 replies to this topic
#2
Posted 14 September 2010 - 04:42 AM
Drivers side back wall. Propane middle I believe. I will take a look in the morning
Cort
Cort
#3
Posted 14 September 2010 - 04:45 AM
Is the taco fuel cap on the drivers side as well?
#4
Posted 14 September 2010 - 04:48 AM
the truck fuel cap...yes.....If i think I know where you are going with this...yes switch it around...
#5
Posted 14 September 2010 - 04:50 AM
Well not so easy. I'm looking to redesign my floor plan but it seems everything is some kind of compromise. I had read in the intarweb that it was not to spec to put the furnace vent on the same side as the fuel access but then I recalled that ATC had it that way so that was obviously false. Then someone else mentioned it's probably not ideal to be venting gases under the awning either so there goes the other side. I'm happy enough with how ATC does it.
#6
Posted 14 September 2010 - 04:52 AM
Jeesh I'm confusing myself. It's FWC that vents on the drivers side (duh)... yes I remember now ATC vents on the back.
#7
Posted 14 September 2010 - 06:14 PM
Everything in life is a compromise.
Nathanael - Large Format Landscape Photography
www.KuenzliPhotography.com
2012 Four Wheel Camper - The FWC Build
"If life was fair, Utah would be closer to home" DD
#8
Posted 14 September 2010 - 07:55 PM
ATC vents on the back near the door. The propane compartment is on the drivers side towards the rear corner.
I'd be more concerned with the propane venting than with gas fumes reaching the furnace, unless I misunderstood.
Once had 2007 Tundra TRD 4x4 5.7 SR5 w/ Firestone bags, Bilstein 5100s in front, Total Chaos shackles rear, 275/70/18 E rated Michelin LTX AT2
2007 ATC Bobcat for sale
Now, just roaming around in a stock Land Cruiser (not stock for long though... bawahahha [evil laugh])
