Wander the West: Gap betwen truck side and camper overhang? - Wander the West
  • (2 Pages)
  • 1
  • 2
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   Land-roamer Icon
  • Advanced Member
  • Group: Members
  • LocationOttawa, Ontario, Canada
Posted 25 May 2012 - 06:30 PM
Another question re: my 10ft NCO installation on my pickup.
I built a wood and insulation platform in the bed of the truck prior to installation, which has raised the camper. So there is a gap between the top of the truck bed sides and the bottom of the side overhangs of the camper. I thought it might be useful to provide some support for the side overhangs, so installed a length of 2x4 on the truck bed sides and used wood shims to fill in the gap and provide support.
Unfortunately, while driving on bumpy roads, the flexing of the bed and the camper means that the shims come loose and fall off, and the 2x4 threatens to fall off (since it's not secured).
1. do I NEED to provide support to the side overhangs of the camper in the manner described?
2. if yes, how would you suggest I get something appropriate to fill the gap and provide the support in a way that won't come apart on the road?
Here are a couple of pics of my installation:
Attached thumbnail(s)
  • Attached Image
  • Attached Image
  • Attached Image
0
#2 User is offline   Phird05 Icon
  • Senior Member
  • Group: Members
  • LocationCrested Butte, CO
Posted 25 May 2012 - 06:52 PM
No, you do not need to support the overhang. The camper itself supports this. I would also think the threat of damage to the camper would happen if you chocked something between the bed rail and the camper, as there is always going to be some movement there, as minimal as it may be. Hope this helps.
Good Camping!
2008 F-150 5.4L QC 4x4, ride rite air bags, 2009 Hallmark Milner LX
0
#3 User is offline   Land-roamer Icon
  • Advanced Member
  • Group: Members
Posted 25 May 2012 - 08:01 PM
Thanks Paul! Glad to know I don't need to support the overhangs, or fill that gap with anything. One less thing to worry about. I may try to put something there to prevent some water from getting into the truck bed.
Best regards,
--Robert
0
#4 User is offline   Rusty Icon
  • Senior Member
  • View gallery
  • Group: Members
  • LocationSanta Rosa, Calif
Posted 30 May 2012 - 01:58 AM
Robert.....
On most modern campers there is little need for those shims...but with older alaskans the framework is simple plywood joints, nailed and without backing or corner blocking in many cases. The flexing, on older Alaskans...will in fact weaken the seating joints..especially at the front edge.
I milled and installed pieces of white cedar...attached to the camper with polyurethane adhesive, about 15 years ago. It keeps the jack brackets from digging into the bed walls and provides support for the seats.
On many of the older Alaskans the rear door had a piece of angle iron which was cut out for the door bottom.....if you inspect yours you may find the edges of the door cut in the iron have cracked. The iron was placed there to strengthen the door opening and minimize the very type of flexing your preventing by installing those shims.
They will stabilize the camper and minimize major joint repairs later.
2003 Ford 250 Superduty Crew....
7.3L PowerStroke diesel
1970 10" NCO Alaskan
Firestone airbags
pulling a 18' Silver Streak runabout
0
#5 User is offline   Land-roamer Icon
  • Advanced Member
  • Group: Members
Posted 03 June 2012 - 07:36 PM
View PostRusty, on 29 May 2012 - 08:58 PM, said:
Robert.....
Thanks Rusty. Any chance you may be able to upload a couple of pictures of those pieces of white cedar so I can see what they look like and where you installed them? (picture is worth a thousand words, as they say...)
I'll check the door bottom as you suggest.
Thanks.
0
#6 User is offline   Rusty Icon
  • Senior Member
  • View gallery
  • Group: Members
Posted 04 June 2012 - 03:06 PM
Robert,
Those cracks will show themselves as hairlines from the corners of the cutout for the door. They're common and nothing to worry about...part of owning an older Alaskan. It was their way of making an attempt to minimize the flexing of the unit with the door removing so much of the structure at the rear....I'll shoot some photos of the particular locations...but they will be specific to your truck and how you have it mounted....I have two pieces, one fore and one aft...placed carefully to miss the tiedowns I have mounted in the stake holes for my truck. They bear on the top of the bed edge between the stake holes.Posted Image
Posted Image
Posted Image
Firestone airbags
0
#7 User is offline   Land-roamer Icon
  • Advanced Member
  • Group: Members
Posted 07 June 2012 - 02:35 AM
View PostRusty, on 04 June 2012 - 10:06 AM, said:
Robert,
Thanks Rusty! I'll try to come up with something similar for supporting the seat bases on the bed walls. Not sure I can get something in there with the camper on, but I suppose if I have to jack it up a bit it's not too bad. I see you put a strip of foam on the bottom which is a good idea. I assume that with your cedar strips resting on the bed walls, there is no gap left, so the camper is supported at the same time on the floor and on the bed walls. Plus having chosen cedar means that wood won't rot under there. Good solution, I'll inspire myself and try to come up with something half decent before I put too many miles on the camper. Cheers.
0
#8 User is offline   Rusty Icon
  • Senior Member
  • View gallery
  • Group: Members
Posted 07 June 2012 - 07:49 PM
Robert,
best to be done with the camper off...but can be done with the polyurethane adhesive by jacking it up just far enough to slip the pieces in there...then lower the camper and allow 24 hours to cure...very tough stuff...and it allows for some lateral movement.
Firestone airbags
0
#9 User is offline   Land-roamer Icon
  • Advanced Member
  • Group: Members
Posted 13 June 2012 - 03:55 PM
What do you think of THIS solution?
I had in my garage a couple of lengths of docking foam (to attach to sides of docks to prevent damaging boats). Nice sturdy foam which compresses a bit under load, but re-establishes its shape.
It fits quite snugly between the camper overhang bottom and top of truck bed sides. I could glue the top part of the foam to the camper overhang. I could get lengths to completely seal the sides of the truck bed, thereby not only providing support to the camper overhangs, but also block out dust and water from entering the truck box.
Will this provide sufficient support for the camper overhangs?
Pictures attached.
0
#10 User is offline   Desert Rancher Icon
  • Senior Member
  • Group: Members
  • LocationSocal desert
Posted 13 June 2012 - 06:33 PM
That looks good. I used the black foam pipe insulation on mine.
You may find that over time it may squeeze or work its way out due to the slight movement of the camper and bed.
I ran a bead of RTV along the bottom side of the camper and it has held the foam in place.
~DR
Granbaby ridin' on an F250HD 4x4, International Diesel powered T444E
"And camping will grant each man new hope...as sleep brings dreams of home"
0
  • (2 Pages)
  • 1
  • 2
1 User(s) are reading this topic
