84 fleet bent roof... Yakima roof rack!
#1
Posted 25 February 2015 - 07:19 PM
It seems my options are: ditch the rack, support it from the inside every time I pop it up, or put hard foam supports under the bars on each roof member to try and defray the weight over the whole roof. Has anyone dealt with this? Suggestions? Thanks!
Luke
#2
Posted 25 February 2015 - 07:27 PM
The FWC roof is bending or the cross bars on the rack are bending? My first thought is that you may want to get some flat track, then mount the feet for the cross bars on that, the flat track widens the surface area to carry the load and also makes your positioning of the rack bars easy you can slide them fore and aft for your various needs etc. The typical Yakima bars are rated for a standard 150lb static load.
Edited by CALIcamperdad, 25 February 2015 - 07:31 PM.
#4
Posted 25 February 2015 - 07:58 PM
#5
Posted 25 February 2015 - 08:18 PM
nearlyroadready.
maybe the way i built a roof rack would end your problem.
i used 1" thin wall steel tubing as 3 cross bars .
cross bars were mounted to the edge of roof with 1"flat stock approx 6" for each
mounting point (6 total),t shaped with single t pointing up,to this the cross bars were wielded.
brackets were then screwed to roof edge with 4 screws for each bracket.
carried kayak (double 90# at least)
never had any failures.
pictures might give you ideas.
Les,lqhikers
#6
Posted 25 February 2015 - 08:38 PM
The roof is bending, not the bars. I thought about going that way but didn't have the budget and all the weight would still be focused on just two of the roof's inner aluminum tubes.
Sounds like you need to spread the load out over a larger foot print along the edge of the roof so your getting less load in a very small area. The flat track idea run along the outer edge of the roof frame should do the same thing regarding spreading the load out vs a small foot print etc. The flat track would also let you add a cross bar if you wanted too.
Edited by CALIcamperdad, 25 February 2015 - 08:39 PM.
#7
Posted 26 February 2015 - 02:37 PM
Woodland, CA 95776
www.fourwh.com --- e-mail = stan@fourwh.com
#8
Posted 26 February 2015 - 08:48 PM
sure would like to see what "Les,lqhikers" is doing with a closeup pic. I use yakima towers to side mounts and long crossbars. I have had no problems even carrying 4 kayaks except a sag in the middle. This can be supported with a foam block. Many a pickup camper shell employs this same technology, look around a parking lot. I wonder what part of the roof is bending?
#9
Posted 26 February 2015 - 10:35 PM
bike4me,
as many know i have a hard time with posting,just got back into being able to post pictures,so what i posted is the best i can do.
took me a while to figure out before just clicking on thumbnail makes it bigger!
do not know if it works for you.
you can tell how they mount do not really close up to figure out,just basic wielding skills! ha.ha.
the cradles for the kayak just bolt onto cross bars.
Les,lqhiker
