Charging House Battery from Engine
#11
Posted 07 June 2015 - 10:53 AM
#12
Posted 15 June 2015 - 01:28 AM
K, I've done a little more research and pulled some panels off.
-Doing a little testing, not exactly sure this is a good test, but I am plugged into shore power currently, the system is to my knowledge supposed to continue running all power to fridge, fan, plugs, lights etc, all off the shore power. To test, I unplugged my 12v cables from the camper to the battery and all power turned off except for the 120v plugs. Is this right or is something not working correctly? I was assuming that being plugged into shore power was both powering my stuff as well as trickle charging my house battery, which it isn't doing that either.
Nick, that is a valid test for your converter/charger - it should power everything and charge the battery from shore power. The converter probably has its own AC circuit breaker and plug on the back of the AC/DC distribution panel.
My converter had a blown fuse. I had to remove the converter from the channel to find the fuse. Before you yank on the fuse, loosen a couple of small screws that hold it in place (standard automotive ATC 30 amp fuse).
Also tagged with one or more of these keywords: tundra, fwc, four wheel camper, battery, charge, power, 12v
Trucks, Campers, Gear Forums →
Gear Exchange →
2011 Four Wheel Hawk in excellent conditionStarted by surfstrongfit , 20 Apr 2024 hawk, four wheel camper |
Gear Exchange →
2011 FWC Kestrel $16,800 Akron, OHStarted by Smorgash , 15 Apr 2024 Kestrel, FWC, Four Wheel Camper and 1 more... |
Gear Exchange →
2009 Eagle Four Wheel Camper Madison WisconsinStarted by WiscoK , 10 Apr 2024 truck camper, FWC |
Gear Exchange →
FS: 2023 FWC Project M for 5.5' Full Size Beds - $14,000 - Colchester, VTStarted by danruss , 06 Apr 2024 fwc, project m, tundra, 5.5, 2023 |
Gear Exchange →
For Sale: upgraded 2001 FWC EagleStarted by Wildcat , 26 Feb 2024 FWC, Eagle |
1 user(s) are reading this topic
