Fantastic Fan variable speed control
Fan Fantastic Fan Modification Speed adjustment
108 replies to this topic
#1 photohc
photohc
  • 267 posts
  • LocationSo. Calif.
Posted 14 July 2015 - 07:32 AM
I thought I would post this modification I did recently on my Fantastic Fan for anyone that might be interested. I’ve been frustrated with the speed of this fan as the three settings seem to make the fan run 1.fast, 2.faster, and 3.fastest. Too much air movement and noise for night time usage (as well as the amperage used).
I unscrewed the unit from the inside to discover that the three position speed switch was simply selecting different resistance to control the voltage sent to the motor, thus controlling the speed. This is a wasteful use of energy as the reduction in voltage is accomplished by the resistance introduced and energy is dissapated in heat.
The solution is to use a PWM DC motor speed regulator controller. You can find these on eBay at dirt cheap prices. I paid $2.76 shipped from China. Who knows how they make money on these at that price. A 4 amp unit will do as the fan will draw a maximum of 3 amps. This controller controls the speed of the motor by varying the pulse width sent to the motor instead of reducing the voltage.
Basically you have 2 wires for 12v in and 2 wires out to the fan motor. You just need to figure out which wires are the 12v source and which one’s go the fan motor. I snipped off the resistors on the 3 way switch but I later discovered I didn’t need to do that as a unused terminal on the switch bypassed those resistors.
I hot glued the controller to the plastic wall of the fan and drilled a hole for the speed control variable resistor.
The fan now can be reduced in speed to a much slower and quiet speed. I can vary the amperage from a low of .5 to a max of 3.0. Prior to this install, the fan drew 1.5 amps at its slowest speed and 3 amps at it’s fastest.
Here are some photos during my installation:
Done!
  • 2
Ford 2018 F250 FX4,Lariat, Gasser. FWC 2013 Hawk W6QN (formerly KH6FBU)
#2 Happyjax
Happyjax
  • 1,444 posts
  • LocationMaryland
Posted 14 July 2015 - 11:22 AM
Nice job. Thanks for the share:)
#3 bfh4n
bfh4n
  • 235 posts
  • LocationLovingston, Virginia
Posted 14 July 2015 - 01:40 PM
Nice job photohc and nice write-up.
One of my fans has the Fantasic speed controller with a remote, which gives about 14 speeds. It is kind of klunky to operate but works well and allows nice quiet, slow speeds (and low current). The other fan has the plain 3-speed switch. So I might modify it as you did.
Any chance you can give us a link to your source for the PWM contoller?
Thanks...
- Bernard
2014 silver Fleet front-dinette
2007 Tacoma Access Cab 4WD TRD V6 6-speed
#4 photohc
photohc
  • 267 posts
Posted 14 July 2015 - 05:11 PM
Here is a link to one of many to choose from. I couldn't locate the one I got but this is pretty close relative to the amperage and physical size needed.
http://www.ebay.com/...=item257c75d2ea
#5 billharr
billharr
  • 2,824 posts
  • LocationStockton CA
Posted 14 July 2015 - 07:51 PM
Thanks for the link.
Just ordered one. Going to change out to get aways from the resistance control and save some power.
#6 ski3pin
ski3pin
    Belay On
  • Site Team
  • 15,338 posts
  • LocationSierra Nevada Range
Posted 14 July 2015 - 08:17 PM
Thanks for the info; ordered one also.
#7 takesiteasy
takesiteasy
  • 2,588 posts
  • LocationMinnesota
Posted 15 July 2015 - 02:43 AM
I wonder if I could do similar mod to our fans. We have the variable speed fans with remote controls. I like them because they have a rain sensor that closes the vents if it rains. The trouble with them is the remote control receiver and rain sensor draw current all the time whether the fans are being used or not resulting in unnecessary battery drain. I didn't know that when I ordered them. I put a master switch on the circuit so I could turn them off but maybe I could eliminate the remotes with this mod. Hmmmm....
2011 Tacoma AC TRD
ATC Custom Shell
travelswithrockythedog.blogspot.com
#8 huskyrunnr
huskyrunnr
  • 71 posts
Posted 15 July 2015 - 07:32 AM
Nice writeup on your mod! Any problems with humming? I couldn't find a spec on what freq the pwm controller is running at. If no hum then it is fast enough!
#9 photohc
photohc
  • 267 posts
Posted 15 July 2015 - 08:14 AM
I haven't found any issues (no humming)  with this modification. Just a nice smooth start from stop to full speed.
#10 Lighthawk
Lighthawk
    Weekend warrior
  • 3,319 posts
  • LocationNevada City, CA
Posted 15 July 2015 - 08:10 PM
billharr, on 14 Jul 2015 - 12:51 PM, said:snapback.png
x 3!!   I wonder if the company notices a sudden spike in sales?  :huh:
Excellent documentatation, photohc.
with 2000w inverter and external 120v output and 12v solar input with 100w portable solar.   http://lighthawkphoto.com
Also tagged with one or more of these keywords: Fan, Fantastic Fan, Modification, Speed adjustment
