see post #75 above... added a large capacitor across the power leads. Squeaking gone.
Fantastic Fan variable speed control
#81
Posted 26 January 2020 - 06:13 AM
#82
Posted 26 January 2020 - 12:35 PM
Not sure what's going on... mine is silent on exhaust (a bit of a cyclical clack on intake)... it might be the unit as they are not well made and may have interference of some kind. A couple folks have said that they bought two after the first failed. Might just be a crap shoot as to the quality. Mine has held out for a total of daily use for 3 months over two years (touch wood). Could the noise be coming from the motor bearing? With uneven weighted fan blades putting a piece of duct tape on a blade to balance can help if that is the source.
#83
Posted 26 January 2020 - 12:44 PM
Hey Vic... just saw your post (read the other post from mail) ... do you have a link to said capacitor? Or info on it?
#84
Posted 26 January 2020 - 02:10 PM
Yes-more info on the capicator you used,please.
2017 Tacoma TRD 4x4 Offroad / 2014 ATC Bobcat / Tucson,Az
#85
Posted 26 January 2020 - 09:05 PM
oh man, I just looked in my spare parts bin and put in the biggest one I could fit. Electrolytic type for sure. I could get pics?
Vic
#86
Posted 30 January 2020 - 03:11 AM
Vic
Polarized or non polarized and the values of the cap would be good info if possible.Thanks
#87
Posted 31 January 2020 - 04:00 AM
OK, so here is a trial fit of the PWM speed controller:
#88
Posted 31 January 2020 - 05:59 AM
Vic,Thanks for the info and pics.
#89
Posted 06 February 2020 - 06:19 PM
With my front vent I had to order a fan & other material to install. Decided I liked having a rear fan. Not much draw. The front vent was more problematic than the rear vent. The rear was just about altering the already installed FWC 3spd fan. The front went pretty smoothly with the actual controller unit much like the rear install. Here is where I had an issue ...
Turned the fan on & it instantly blew the fuse. New fuse, blew it, third fuse blew it. I figured it was the controller. Ordered another controller & finally got around to install months later. Same issue, instantly blew the fuse. My son suggested the incoming FWC wiring could be the issue. Well, Yes, the White & Black were Reversed. Not sure if this is typical. Luckily the fuse took the hit like it should. I have not read this entire thread to see if this occurred elsewhere. Encountering reversed polarity is not expected.
Edited by Stokeme, 06 February 2020 - 06:47 PM.
#90
Posted 06 February 2020 - 07:47 PM
Black/White reversed? Yup. Been there, seen that. In my world, black is ground. NOT in the RV world.
https://www.google.c...chrome&ie=UTF-8
Also tagged with one or more of these keywords: Fan, Fantastic Fan, Modification, Speed adjustment
Trucks, Campers, Gear Forums →
Truck Campers →
Four Wheel Camper Discussions →
Power for fan over bed ?Started by BMH44 , 17 Apr 2024 fan, wiring |
Truck Campers →
2009 Eagle swap out to a fanStarted by Greeneggsslc , 24 Feb 2020 fan, upgrade, prewired |
Truck Campers →
Hawk - Shower repair and Fanstistic FanStarted by wpage66 , 22 Oct 2016 repairs, Shower, vent, fan |
