I have two rigid solar panels on my roof - about 18 lbs each with mounting hardware. They are mounted to Yakima tracks so I have the option of moving them around. I have two roof vents so the potential locations are front, center, rear - one will fit in each location. The two panels are currently mounted center and rear.
In terms of lifting the roof, I can do it now with a little bit of foam for my head (also have the speaker stand), but I'll probably be adding external struts, so what is the best configuration? My options are obviously
- center and rear (current)
- front and rear
- front and center
