Insomnia makes you do searches on WTW..
I just ordered this re-light kit, should be here when I get back from my trip, hope it goes well as far as the install goes, I am usually pretty adept at this kind of thing. I am fairly strict on my leveling, I use a combo of two inclinometers mounted to the outside, plus one loose that sits on the counter, floor or my center console and finally my iPhone app. I won't be driving using propane, just when parked. I also strongly consider wind direction and velocity, even go as far as check the weather to help plan it.
On another note, I was trying to figure out what output or cooling is being done on 12V DC while driving. The manual says that the fridge works on continuous, not via the thermostat like on AC. This is for the Dometic 3-way ( RM-2193 ). So is the thermostat knob ( 0-7 ) non-applicable when using 12 V DC?
By the way, I had no problem lighting and using the propane setting on the fridge while parked at the top of Imogene Pass for 24 hours at over 13,000 feet for what that is worth.
I have had my new pop-up for a month and 4 days now, have slept in and used it for 18 days, it is getting close to being fully dialed. Folks like you and threads like these really help me cut to the chase in terms of getting the most out of this new tool for my work, thanks!
