Last minute wiring advice?
hawk flat bed wiring
17 replies to this topic
#11 Durango1
Durango1
  • 532 posts
Posted 18 October 2015 - 06:29 PM
Thanks, everyone. I'm going to try and pick up some 6 gauge stranded wire along the way. No one has the wire reducers in stock. But I can leave the wire a bit long and add them later.
I really appreciate the help. We're leaving in a few hours for Jackson and will stay in Green River UT or Provo (if we are "energetic") tonight.
Steve
#12 billharr
billharr
  • 2,824 posts
  • LocationStockton CA
Posted 18 October 2015 - 07:10 PM
Steve
You could leave a few inches long and add later. If you can not find them I would do the following. Push a couple of inches of 10 gauge into the 6 gauge, solder all together and cover with heat shrink tube. Done neatly this might look better than a reducer.
Edit: to clarify cut two inches of 10 gauge and push about 1/2 inch into the 6 gauge. Solder this 1/2 inch area. and cover this area with heat shrink tubing.
Edited by billharr, 18 October 2015 - 07:13 PM.
#13 Durango1
Durango1
  • 532 posts
Posted 20 October 2015 - 11:27 AM
Hey guys,
So Sioux and I dragged our tired butts into Denny's FWC shop here in Jackson yesterday afternoon at 4:30 and he put me to work right away. Since the Hawk is going to be mounted "permanently" on the flat bed we decided to hard wire the 6 gauge right to the camper wire. This will avoid all the connector drama! And yes, Bill, we're going to solder and heat shrink it.
We're thinking about running about both wires of the duplex 10 gauge that comes with the camper back for the ground. Or is this overkill? Thoughts? (I'm meeting him at 7:00 AM to get started. The man is a slave driver!)
Steve
#14 craig333
craig333
    Riley's Human
  • 8,014 posts
  • LocationSacramento
Posted 20 October 2015 - 10:25 PM
Someday you'll want to do some maintenance and I just hope you remember its hard wired. I've made that mistake myself  :(
#15 ntsqd
ntsqd
    Custom User Title
  • 2,881 posts
  • LocationNorth So.CA
Posted 21 October 2015 - 12:50 AM
I'd use the same gauge for both power and ground. It is likely that one of the 10 ga. wires is red. Using it as a ground wire will be confusing in the future.
Leave a little slack in the wires in some area where a connector can be added later. You will eventually want or need one. I used an Anderson Power Pole for our connector. Can get those in a range of ampacities with contacts for various wire gauges within each size.
Thom
Where does that road go?
#16 billharr
billharr
  • 2,824 posts
Posted 21 October 2015 - 01:31 AM
Great advice, I have the Anderson connector for +/- 12 volt and a round plug for back up lights (have a relay that turns on rear lights) and clearance lights
#17 Captm
Captm
  • 269 posts
  • LocationPort Angeles
Posted 24 October 2015 - 01:26 AM
Hey Steve,
  Congrats on the new rig - it a great looking combo with your truck.  So much room in the flatbed Hawk, thanks for the tour.   Did you and Denny wrap it up on Tuesday?  I assume your still out camping -  we look forward to hearing about your shake down trip. Molly and I hope to meet up with you again.
Cheers!
2005 Tacoma Dbl cab LB 4x4
2014 Fleet shell
#18 Durango1
Durango1
  • 532 posts
Posted 24 October 2015 - 08:13 PM
Hey Steve,
Cheers!
Yep. we got 'er done Tuesday. Just got back to Durango last night. Everything performed great including your trolling plug! Sorry I couldn't spend more time with you folks but as you saw Denny and I were working like slaves!
Steve
PS Will post photos IF I ever figger out how to do it!
Also tagged with one or more of these keywords: hawk, flat bed, wiring
