I had to cancel the orders for the battery and charge controller due to the following:
I live and work at 8,000 feet in a ski town, the camper is on full time and is exposed to temps below freezing quite often, maybe more than half the year. It has been confirmed by both the seller of the battery and the maker of the SBMS60 charge controller that I should not apply a charge to a LiFePO4 battery when the temperature is below freezing. One can discharge a Lithium Ion battery when it is cold with some "Voltage Sag" but not charge them without the risk of damage to the cells. The cells in electric cars use low and high temp cut outs that allow safe use of them not to mention battery heaters.
I found this out today while reading the manual for the SBMS60. There are things I *could* do in order to overcome this but I feel in the long run it is just not worth it.
So to anyone considering a move to what is a very attractive net power to weight ratio gain of LiFePO4 batteries, at this stage in the technology, they are best used in either off grid home or RV environments where the ambient temps are above freezing most of the time.
Bummed it did not work out for me but I am glad I got it figured out well before I started tearing into the revision of an excellent existing system that uses proven AGM batteries.
Edited by Kodachrome, 15 June 2016 - 09:01 PM.
