OK...I noticed that my RideRite airbags require 42 psi on left and 29 psi on right to put the rear wheel wells within 1/8" of being at the same height [top @ 36 1/2"]. Same for rear of camper; right is still 1/8" higher than left with those airbag pressures. This is with all fluids aboard.
Our 2016 Hawk has the works...130 L Isotherm frig, 6 gal hot water heater, out side shower, propane tanks, furnace, sink and cabinets and I believe the 20 gal water tank all on the left side of the Hawk...right side has awning, dual batteries, side dinette and a couple of cabinets.
So the question is: Is a 2016 Hawk heavier on the left side when wet?
And would that be why I am seeing a difference in airbag pressures to level the camper right to left.
Those with a first generation Tundra [ours is an '05 AC] and airbags; do you use different airbag pressures to level out your Hawk?
Thanks as always for any pearls of wisdom or WAGs!
Phil
