Adding a propane compartment, furnace to shell model
13 replies to this topic
#1 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,898 posts
  • LocationCalgary, Alberta
Posted 29 July 2016 - 05:35 AM
So, if a person was to have nearly clinched a deal on a bare shell model without a propane system, what are the steps/parts I would need to get to add propane and a heater?
I spotted these threads:
http://www.wanderthe...ne compartment
https://performanceg...urnace-install/
But can't find anything on actually adding in a propane compartment.
I also kind of like the idea of having the propane tank outside like the propex heater thread shows, but mounted to the camper vs taking up space inside.
Thoughts?  Ideas and pictures are most welcome!
#2 Old Crow
Old Crow
    Searching....
  • 1,059 posts
  • LocationSouth Central PA
Posted 29 July 2016 - 04:41 PM
Vic-
In this Expedition Portal thread (at post #9), Bill Harr links to this WTW thread which includes a propane locker build in an Ocelot shell (see posts #16, #18, and #41). (The last reminds us you'll need a propane detector).
also- I thought this web page on building a propane compartment in a Promaster van an interesting read, particularly for the access door and venting.
Edited by Old Crow, 29 July 2016 - 04:46 PM.
'01 FWC Hawk shell on a '13 Tundra Double-Cab  + '19 Ford Transit van with Quigley 4x4 option
#3 nikonron
nikonron
  • 576 posts
  • Locationowensboro,ky
Posted 30 July 2016 - 02:13 PM
You can also buy the propane box kit from Four Wheel campers. The space on the back of the camper is already framed in. Just cut out the siding and install the exterior door.  Ron
#4 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,898 posts
Posted 06 August 2016 - 12:14 AM
thanks guys!
#5 liftedlimo
liftedlimo
  • PipPip
  • 25 posts
  • LocationVancouver, wa
Posted 08 August 2016 - 05:29 AM
I ordered the 4wc box and door for my keystone shell. I had to cut it one if the interior welded bars, fab up a wood spacer for the screws to go into and then made spacers that kept the box the right height from the floor. Worked out well. I still need to plumb it but it shouldn't be a problem.
#6 liftedlimo
liftedlimo
  • PipPip
  • 25 posts
Posted 08 August 2016 - 05:34 AM
Here is where the propane compartment is mounted.
This shell is made for the older lay down style propane tank and door. I'm updating to the new removable double tank bottles and door.
To do this took a little engineering. First I had to remove the lower upper brace to make the new taller narrower door fit.
The door test fitting.
Edited by liftedlimo, 16 October 2016 - 04:03 PM.
#7 liftedlimo
liftedlimo
  • PipPip
  • 25 posts
Posted 08 August 2016 - 06:06 AM
The wood is cut into a u shape. The bottom has a metal piece you can screw into but the other side's don't.
This is the new size door with the new size bottles so it doesn't fit perfectly. The old style lay down bottle and larger door was what this late 2000's camper was built for.
Edited by liftedlimo, 16 October 2016 - 04:00 PM.
#8 liftedlimo
liftedlimo
  • PipPip
  • 25 posts
Posted 08 August 2016 - 06:16 AM
Where the metal sheet is with the holes is the furnace exhaust. I tried to build it into a different spot but now I'm putting it back there. The furnace mounts on the face of your cabinet and the exhaust mounts to the outside where that plate is.
This was the first version and I was going to put the furnace to the right of the big cabinet. I've now made a new cabinet that is 2 or 3 inches wider like the stock one to put the furnace in the stock location.
#9 osu11
osu11
    Newbie
  • Pip
  • 7 posts
Posted 01 September 2016 - 08:10 PM
Great Work.  If you don't mind me asking what did FWC want for the door and propane locker?  I am in the process of doing the same thing to my falcon.
#10 liftedlimo
liftedlimo
  • PipPip
  • 25 posts
Posted 01 September 2016 - 11:11 PM
I think it was a couple hundred bucks for both parts. It's a little steep, but all the other options I researched were less storage and more hassle not to mention just as expensive.
