You're right, Bad Habit. There will be more (hopefully minor) catastrophes along the road and the end will undoubtedly be a tragic one in a God-forsaken wash in the middle of nowhere. But for now we're looking pretty solid and are ready for another season of seeing where our truck/camper can get us to.
Smlobx: Mounting plates are installed over the carpet. You could cut out a section of carpet to mount the plates more cleanly and have them sit a bit closer to flush with the carpet surface beneath the cushions. Maybe we'll do that to ours now that you mention it. I will have to at least make a mental note to tighten the carriage bolts when we've driven it a bit, the carpet will probably compress some.
The metal fabricator drilled the holes for the cotter pins. I didn't ask how he did it exactly, but I suspect he used some kind of industrial drill press and vice. I would have probably injured myself trying to work that out with a small vice and hand held power drill.
It's a shame if you don't have a metal fabricator who specializes in off road vehicles in your area. Our local shop is fantastic. The 4x4 supply place everybody goes to will only install factory-made stuff. Fortunately, they don't hesitate to refer people to the fabricator when custom work needs to be done.
By the way, Dodge doesn't offer factory-made skid plates for their 2500s(!). Even if they did, the plates truck manufacturers make tend to be pretty wimpy for serious off roading.
So to summarize our experience (thus far!) for the benefit of others:
If we'd known before what we know now, we'd have scrapped the original plates and had some larger and stronger ones made. Could probably do that without going to a specialty metal fabricator, although getting the parts cut and drilled and welded for self-install would probably not have cost much. Without the damage we wouldn't make plates as big as the ones we have now, but at least long enough to reach the back of the dinette bench and the under-stove cabinet (maybe 10-12" long?) and probably the 7" width we now have. Strong steel turnbuckle mounts welded to the underside plates also seem like a no-brainer.
We'll do our best to dial in the suspension (adjustable shocks and air bags) and religiously air down tires to minimize shock-loading of the anchoring points. And we'll keep the rear turnbuckles just snug enough so that the rear of the camper doesn't jump up and down in the bed on bumpy roads.
But we're not going to dial back the ruggedness of the roads we drive. Quite the opposite. We fully intend to keep living and learning. And our truck/camper will undoubtedly be getting more of that attention it so desperately wants!
Edited by DoGMAtix, 24 February 2017 - 05:55 PM.
