Has anyone installed a diesel heater in a truck camper
#1
Posted 21 March 2017 - 02:53 PM
#2
Posted 21 March 2017 - 08:09 PM
If I recall correctly the XP Camper uses a Webasto Diesel Heater. However, I have not seen one put in a FWC - yet.
Regards,
Craig
Edited by ckent323, 21 March 2017 - 08:09 PM.
#3
Posted 21 March 2017 - 08:48 PM
In my Sprinter build I installed a Webasto diesel bunk heater tapped into my main fuel tank and it also has worked very well.
I highly recommend either Webasto or Espar.
2016 Sprinter Silver Gray 144 Std. Roof 4x4. 3.0 diesle, Cooper "Dicoverer" ST Maxx 255/85/16
#4
Posted 21 March 2017 - 11:03 PM
I've used espars to preheat my trucks for years. If I was building a camper I would seriously consider this route (single fuel source). Locally, there's an experiment in heating a small house with a webasto.
#5
Posted 07 April 2017 - 12:00 AM
I will be installing a Webasto diesel heater in a Hawk flatbed. Will post about the process when it is done.
#6
Posted 07 April 2017 - 01:52 AM
I used to have an XPCamper and it had a Webasto Duel Top. This unit provided heat as well as hot H20 and worked very well.
I camp frequently with Marc and I'll add, even with a muffler, the Webasto is very loud outside the van. It sounds
like a small jet engine running. I make it a point to park on the opposite side of the van from the heater exhaust. Even
then, it's quite audible. It's the nature of the beast.
2007 Dodge 2500 5.9 CTD QC 4X4, *1996 FWC/ATC hybrid* *2021.5 GeoPro 19FBS* "If you can read this, Thank a Teacher. Because you read this in English, Thank a Vet."
#7
Posted 07 April 2017 - 03:40 AM
I believe Wallas makes a heater only version.
https://www.scanmari...nd/stoveheaters
I am haunted by waters
#8
Posted 07 April 2017 - 06:17 AM
Instead of an electrically powered fan, have you looked at a Stirling engine fan? Put it on the hotter side for more air flow. No electricity required. More expensive, perhaps, but think of the warm fuzzies from using a more eco-friendly solution.--snip--
We put an ECO fan on the cooler of the two burners and use it instead of the fan in the lid. --snip--
https://www.stirling...gine-stove-fan/
Paul.
Edited by PaulT, 07 April 2017 - 06:19 AM.
#9
Posted 07 April 2017 - 06:32 AM
Is your fan the Peltier driven unit?
#10
Posted 07 April 2017 - 12:30 PM
Steve,
Not a stirling engine, it uses a dissimilar metal stack to create a small current and drive the fan. I believe that is the Peltier engine technology.
