First time camper owner - looking to add struts to popup
struts camper four wheel popup springs
13 replies to this topic
#1 grete
grete
    Newbie
  • Pip
  • 6 posts
  • LocationColorado
Posted 24 March 2017 - 05:33 PM
Hey all!
So I'm a first time camper owner as of hopefully this week. I am looking at an '84 fourwheel popup. I think it is a Fleet model, because it fits in my Tacoma bed (6 ft) but the current owner told me it is a granby...I think its too small to be a granby though. Regardless, I have a bit of trouble lifting the roof on my own, as I am a pretty small framed female. I want to add some sort of lifting mechanism, but I am also someone who knows little-to-nothing about fixing things up (this is a really big learning endeavor I am embarking on). Does anyone have any information on inexpensive struts (or anything that could help me) and how to install them? I'd rather not order ones from Four Wheel, cause they get pretty costly, but I want something that will work the same and be relatively easy to install. Thanks all!
#2 Casa Escarlata Robles Too
    C'est la vie
  • Site Team
  • 9,286 posts
  • Locationmonterey bay area
Posted 24 March 2017 - 05:53 PM
Welcome to the "cult"
There is a whole "pined" thread about roof lifters.  "Roof lifter shock helper thingies"
Check under the FWC/ATC camper forum. You should find it without any problem.
#3 ski3pin
ski3pin
    Belay On
  • Site Team
  • 15,316 posts
  • LocationSierra Nevada Range
Posted 24 March 2017 - 05:55 PM
http://www.wanderthe...shocks-thingys/
#4 RC Pilot Jim
RC Pilot Jim
  • 1,544 posts
  • LocationSan Diego Calif
Posted 24 March 2017 - 08:12 PM
Welcome to the family, Grete.
Speaker lift is a good way to lift it and it doesn't take up much room. Click on the link to View the video "speaker lift". Cost is around $90. I use it on my Eagle as I have a damaged back. Takes about 3 minutes to put up the top quicker if I used a 12 amp power drill like BobM does in the video.
You can purchase one at any Guitar Center.
Yes Four Wheel is expensive, however they can fix and replace worn out parts that you can't fix yourself or don't know where to get the work done.
You might also contact All Terrain Campers and speak to Marty. That generation camper was manufactured when he worked for Four Wheel prior to 2000
Edited by RC Pilot Jim, 25 March 2017 - 03:36 PM.
Jim
Retired from truck camping June 2021
Our Basic Eagle/Fleet Shell Build
#5 Ronin
Ronin
  • 934 posts
  • LocationPNW
Posted 25 March 2017 - 03:25 PM
Hi and welcome to the group. I'm not sure where you live or what your mechanical abilities are but I had my struts installed by All Terrain Camper located in Sacramento, CA. They charged me $330 for everything and it took about 2 hours. Probably would have been faster but I kept asking Marty questions about the camper and other retrofits I was thinking of doing. If you go the strut route and it's within your budget I have no hesitation recommending ATC. Many happy adventures in your fleet!!
https://www.allterraincampers.com
2019 Tundra 2019 Panther Shell
#6 abqbw
abqbw
  • 106 posts
Posted 26 March 2017 - 01:14 PM
I wonder if the adjustable speaker pole is still available?
I can't find the adjustable speaker stand at the guitar world link at the link provided to the video. The link is two and a half years old...
Does anyone have the Brand and model number of the speaker stand? The title of the thread says "pro audio" which appears to be the brand but I'm not finding that on guitar world's website or by otherwise searching.
Thank you.
#7 jimjxsn
jimjxsn
  • 599 posts
  • LocationRoxborough Park or Buena Vista CO
Posted 26 March 2017 - 02:06 PM
I think this is the speaker stand on Amazon - On Stage SS8800B Plus Power Crank Up Speaker Stand
https://smile.amazon...ture-pcomp-wm-2
~Jim
2000 Tundra AC- 2000 FWC Ranger
2017 Tundra DC - 2017 ATC Panther
#8 abqbw
abqbw
  • 106 posts
Posted 26 March 2017 - 03:14 PM
Great! Thank you!
#9 BobM
BobM
  • 730 posts
Posted 26 March 2017 - 04:51 PM
Here's a video I did on the speaker stand https://youtu.be/bNcr0qgHgjg I don't have the struts and don't need them. If you buy the speaker stand, you will want to drill out the rivets holding the tripod. Save the rubber feet on the tripod and put on the ends of the pole
#10 grete
grete
    Newbie
  • Pip
  • 6 posts
  • LocationColorado
Posted 28 March 2017 - 05:23 PM
Thank you everyone! I really appreciate the info!! apart of the job I have this summer, I need to do quite a bit of off-roading. Does anyone have any experience off-roading with an older model camper on the bed of their truck? My boyfriend keeps telling me the wooden frame is going to fall apart when I take off roading, but I can't help but feel like if I am cautious enough driving, then these things should be durable.
Also tagged with one or more of these keywords: struts, camper, four wheel, popup, springs
