Eagle on Tacoma Help
eagle tacoma toyota fleet
16 replies to this topic
#11 alijabosdotcom
alijabosdotcom
  • PipPip
  • 25 posts
Posted 28 March 2017 - 07:26 PM
Thats the one, they said it was coming to Mass if you did not buy it.  Looks like a nice FWC.  Did you get all that batter power?  Enjoy.
Yes, the battery is massive. 130lbs apparently. https://www.vmaxtank...ry-_p_165.html
 Probably overkill for me but it's installed and I'll use it.
#12 champer
champer
    Newbie
  • Pip
  • 9 posts
Posted 30 March 2017 - 06:02 PM
I also prefer to travel with bikes inside my Eagle. I mounted cargo track each side of the cabin floor and then ran an 18" deep pc of plywood between the two sides with fork mounts screwed into the ply. I can securely carry jerry cans, hi-lift jack, and two bikes all mounted to the ply. More people room with just one bike of course. Straps run to the cargo track moveable rings secure the bike side to side.
#13 Blr
Blr
  • PipPip
  • 16 posts
Posted 30 March 2017 - 06:44 PM
Champer,
I am picking up my shell next week and also have thought about mounting my bikes(expensive) inside the shell. I am trying to envision your setup. Is there any way you could snap a couple picks? Thank you.
#14 alijabosdotcom
alijabosdotcom
  • PipPip
  • 25 posts
Posted 31 March 2017 - 08:08 PM
I'd love to see a photo too! Sounds interesting.
#15 champer
champer
    Newbie
  • Pip
  • 9 posts
Posted 02 April 2017 - 04:26 AM
Here is a pic where you can see the rails on each side and the plywood spanning between with about .5" gap underneath - enough to slip the end of the mat under. There is a midspan support also. Box holds 3 strapped in jerry cans of water or gas. There is a specific cargo track attachment that has a threaded post which I used to hold the ply as it sits on the track. I swapped out turnbuckle doors for aluminum so rings could fit there otherwise doors were fine. The other bike mount goes over where the hi-lift is attached. Lashing down loads helps keep everything stable on dirt roads.
#16 alijabosdotcom
alijabosdotcom
  • PipPip
  • 25 posts
Posted 02 April 2017 - 12:14 PM
Yeah, I was going to go for something like that. I have a fridge in the middle where your jerry can box is and I'm a bit worried about pedals scratching things up but I guess with some care it can be done.
#17 Blr
Blr
  • PipPip
  • 16 posts
Posted 02 April 2017 - 01:51 PM
Thx for posting the pic.
Also tagged with one or more of these keywords: eagle, tacoma, toyota, fleet
