FWC 12V Plug at Truck (What type?)
FWC Fleet
13 replies to this topic
#11 Esus
Esus
  • 118 posts
Posted 12 April 2017 - 08:05 PM
Thanks for the replies, my dealer says that FWC used 10 gauge wire from truck to camper, so I assume I should match from the truck battery to plug.  How high of a fuse should I put at the truck battery to protect from shorts, but allow the battery to charge?
Josh
That FWC still uses a 10 gauge wire is lame. Now would be the time to upgrade it if you want to charge better off the alternator.
2015 Chevy Colorado, 2015 FWC Fleet
#12 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,950 posts
  • LocationCalgary, Alberta
Posted 12 April 2017 - 08:07 PM
This might give you a clue - http://www.powerstre...m/Wire_Size.htm
Do you have a battery separator?
#13 Josh41
Josh41
  • 152 posts
  • LocationMassachusetts
Posted 12 April 2017 - 08:47 PM
The Fleet comes with a BlueSeas separator, not sure which model, should be getting the camper in a few weeks.  Makes sense to increase the wire size, maybe replace FWC to the isolator too.  Am I right that I need a fuse at the truck battery?  I looked at the National Luna install directions, it looks like they have a 100amp fuse between the truck battery and camper battery.  From what I can gather, it seems that I should have the 100 amp fuse at the truck battery to avoid cooking it if the wires from truck battery to camper chafe.
Edited by Josh41, 12 April 2017 - 08:53 PM.
Nissan Frontier 2016 CC LWB, 2" lift, tires, airbags and other stuff
FWC Fleet
Summers Off
#14 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,950 posts
Posted 12 April 2017 - 09:39 PM
i use a 100a, at both ends, but also running 2 awg welding cables
Also tagged with one or more of these keywords: FWC Fleet
