I know that most of you are familiar with how the lift panels will bow when the roof is in the up position. The weight of the roof causes the panels to bow. This will, in turn put stress on the panels.
I have come up with a simple way to relive some of the weight on the lift panels. I measured the height of the inside roof edge down to the seating edge(where the roof rests in the down position). I took that measurement, added approximately 5/16". With that measurement, I made some 3/4" Schedule 80 PVC pipe capped on both ends. I put them in the rear corners of the camper. With them being 5/16" longer than my original measurement, they raised the roof and the lift panel bow decreased.
I think these support posts will help save the lift panels(especially the earlier ones). One caution, I didn't make them too long because I didn't want add stress to the vinyl..
I've included some pictures of the supports and the "tool" I made to install them. The tool is just two pieces of wood with a hinge. The hinge ends are beveled so you can fold it a little when placing the tool on the ledge. Then pushing outward the boards then become straight and push up on the roof. In this position, you can install the support posts.
Here are the pictures:
