FWC factory twin battery parallel hookup question
battery
13 replies to this topic
#11 bike4mee
bike4mee
  • 169 posts
  • LocationDurango Colorado
Posted 16 August 2017 - 01:11 AM
I have 2  batteries. I want to use 1 for my trolling motor, the other stays in the camper to run things. After use I want to charge it with solar during the day. How to wire this? They say if you put another drawn down battery in parallel it could hurt your fully charged battery. Should I get another solar modulator box and charge it away from the first one? Or does it matter?
Also does it matter that both batteries are different manufactures. Like putting duracell and energizer batteries in same flashlight?
#12 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,584 posts
  • LocationNortheast Oregon
Posted 16 August 2017 - 01:50 AM
Don't put them in parallel. Look for a quick disconnect (Anderson?) to move controller output between batteries. Primary stays connected to camper. Or at least, that's my 2ยข worth.
I am haunted by waters
#13 ntsqd
ntsqd
    Custom User Title
  • 2,881 posts
  • LocationNorth So.CA
Posted 16 August 2017 - 04:37 AM
Concur, make up some method to charge them separately. Be that heavy duty jumper cable clamps or pigtails with Anderson connectors or whatever.
Thom
Where does that road go?
#14 PaulT
PaulT
    Need gumbo
  • 2,611 posts
  • LocationHillsboro, Oregon
Posted 16 August 2017 - 06:28 AM
Think of this situation as similar to the truck battery/alternator system and the camper battery/solar system with a battery separator between them. Duplicate that solution between the two batteries in the camper using another ACR. That will allow recharging the trolling battery without affecting the camper battery.
You can think about it as a boat system with the camper battery as the boat starting battery and the trolling battery as the boat house battery.
Use large Anderson connectors to allow easy connect/disconnect of your trolling motor to the ACR & ground. You should be able to set it up so that you don't have to muscle the trolling battery back into the compartment if that helps.
Also tagged with one or more of these keywords: battery
