Before our long trip of this summer (4 California NP’s – Trip Report coming soon!) decided to refurbish the door on our 2002 FWC Hawk that was looking a bit raggedy. Also wanted to see what the PO had hidden under the stainless plate on the outside of the door. I searched a few times but did not find pictures of anyone’s similar refurb process and only mentions of the glass being loose and fixes, so posting some pics here and my process to help others that might want to do this same fix. The glass in the door had some external sealant applied by the PO but the telltale streaks of dirt showed the need for a better job.
Here is how the door looked before with the rusty acorn nuts in need of replacement and a coat of paint.
Removed the door from the hinges, leaving the hinges attached to the frame in the camper. Three screws per hinge and the door came off.
Next removed these screws all around the frame of the door to remove the aluminum framing and then tapped it off the door.
This seal profile I could not find anywhere. So, had to re-use the seals, if someone has found a source please share as I would like to replace it, just cleaned the current one and put it back on.
Out came the lock and the factory installed deadbolt as well, gave both a good cleaning and spray with WD40.
Next was the glass window frame. Remove all the screws around the frame and lift it off. Better to do this on a flat surface with some padding underneath.
These are the culprits. The two small nubs are supposed to hold the glass in place. Two at top and two at the bottom. The intact ones are the top ones. You can also see the silvery sealant that the PO had globbed on to keep the glass sealed.
And here are the same bottom ones that have been sheared off over the years.
Cleaned up all the dirt with a vac and plastic bristle brush and directed attention to this mess that the stainless sheet was hiding.
Painted the door with Rustoleum Oil Based Gloss White after cleaning it with brush, vac and wipe down with alcohol wipe. Replaced the locks securing with caulk and window glazing.
Here is the door back on, looking much cleaner. The plate has received 4 more NP stickers since this refurb and we have driven over 2500miles and everything still is holding up quite well. Hope this helps out someone else.
