Fridge Fan Install
#11
Posted 17 August 2017 - 02:25 PM
#12
Posted 17 August 2017 - 03:49 PM
#13
Posted 18 August 2017 - 06:26 AM
My camper originally came with a 3 way fridge and FWC installed a fan in the exterior vent controlled by a thermal switch in the space behind the fridge. When I converted to a compressor fridge I left it there.
Another problem is that Isotherm / Truckfridge have the compressor mounted in the upper right corner. In my case it was a tight fit in the cabinet creating a closed area that restricted air circulation over the condenser coils. To solve this problem I installed a vent in the cabinet next to the coils that allows cooling air to escape.
#14
Posted 18 August 2017 - 06:38 PM
Ditto. This is a big 140mm 12v fan that I tied into the wiring for the existing fridge fan. It moves a LOT of air and is nearly silent.
#15
Posted 18 August 2017 - 06:45 PM
I think most of the 2 ways come with two vents to the outside, one by the compressor for air exhaust and another down at the bottom for air intake. At least that's the way mine came.
#16
Posted 18 August 2017 - 09:51 PM
Not the TruckFridge like I have.
#17
Posted 18 August 2017 - 11:25 PM
#18
Posted 26 August 2017 - 04:57 PM
Pulled our fans out to get at the new 2-way's connections to trouble-shoot. Found what I'd done wrong, and didn't put the fans back. Inaugural trip to see the appoc-eclipse. New fridge doesn't appear to need them at all. Might put them back as a just-in-case feature, but I'm doubting the need.
Where does that road go?
