Low cost DIY Lithium camper batteries.
Lithium LiFePO4 LFP DIY Batteries
217 replies to this topic
#21 rruff
rruff
  • 91 posts
Posted 04 November 2017 - 04:13 AM
That's an odd thing to want to do.  The battery characteristics are different for starting and long slow draining.  Plus you would need some serious fat wire running to your truck starter.  What is the reason for your idea?
Simplicity and weight savings. Being able to use the alternator for house battery charging without isolation, and getting rid of a starting battery that I don't really need.
AGM or FLA deep cycle batteries will easily start a vehicle if they are big enough, and they only need to be a little larger than the starting battery to account for slightly higher internal resistance. I was planning on ~3x the size so plenty of CCA.
I'd need big wires, but typical starter wires will work. I was planning to put the batteries behind the front seat of the cab.
But... that was AGMs. Thinking about it more, if I use LiFePO4 for the house I can probably forget about alternator charging, because they are not finicky about needing to be topped off the way AGMs are. Just need to make sure my panels and batteries are sized in excess of what I'll use.
#22 rruff
rruff
  • 91 posts
Posted 04 November 2017 - 04:24 AM
If you used it for starting you could see draws more like 100A, so you would want to use heavier gauge bus wire between the cells, and much heavier wire between the packs.  You would also want a BMS/protection circuit rated for a higher current.
Yes, I looked at BMS options and the high power ones are expensive! Plus I'd need a voltage step up on the alternator for it to charge lithium. Thinking it makes the most sense to have them totally separate and just use solar for the house battery.
I've been reading up on connecting the cells and a lot of people are negative about soldering. They say it damages the cells. Spot welders are kinda pricey though. Decent ones are ~$200 with a pen for large packs. Soldering definitely heats up the cell more, but I don't know if anyone has measured if it is enough to matter at all (by life cycling the battery).
#23 PaulT
PaulT
    Need gumbo
  • 1,678 posts
  • LocationHillsboro, Oregon
Posted 04 November 2017 - 06:00 AM
There are many lithium based portable starting packs that contain a 8 to 15 amp lithium battery and are able to start engines. You could look into the technology/circuits that make that happen to see if the technology could be adapted to accomplish what you want.
Having a small starting system in the engine compartment without needing massive wires from the deep cycle camper batteries would be attractive and the starting battery would be charged by the camper system.
I have no idea how practical it could be to invent the system to accomplish what you want, but it seems possible.
  • 1
#24 rando
rando
  • 949 posts
  • LocationColorado
Posted 04 November 2017 - 02:08 PM
I think using separate batteries is still a better idea, but you could at least use a much smaller starting battery as you have the ability to switch in the house battery to help out the starting battery when needed.   This reduces the need to oversize everything in your house battery and gives you some redundancy.
I think the discussion of soldering batteries vs welding batteries is a bit of internet lore.   At least with these larger 32650 cells and a 140W soldering iron I could barely feel that cells warmed up at all while soldering - a few degrees C at most.   The key is to use an aggressive flux, and a high wattage soldering iron/gun so that you only have to apply heat for a few seconds to each cell.   The reason professional pack assemblers use spot welders is that it is much faster and more consistent even with low skilled workers, but the electrical connection is generally not as good as the actual bond area is tiny.
  • 1
2016 Fleet Flatbed
2016 Toyota Tacoma
#25 cwdtmmrs
cwdtmmrs
  • 529 posts
Posted 07 November 2017 - 07:35 AM
rando, very cool project! I have a couple of questions. I do not have solar and only charge from my alternator. Also my battery is mounted in the truck bed in front of the passenger wheel well and is more exposed to the elements. What changes would you make in construction, if any, to accommodate these factors?
Thanks,
cwd
CWDT
#26 rando
rando
  • 949 posts
  • LocationColorado
Posted 07 November 2017 - 03:21 PM
For your application I think you would want some sort of weather proof case - something like a battery box, a plastic ammo can or cheapo pelican case knock off would work well.   Pick something big enough to hold the number of cells you want, then start playing some tetris to figure out the cell arrangement.  Using the smaller cylindrical cells means you can arrange them to fit just about any shape.
As for alternator charging, it all depends on your alternator voltage.   In my case, my alternator is ECU controlled and quickly drops down to ~13.5V, when combined with my skinnier wires to the battery doesn't provide much charging current.   If your alternator stays up at 13.9 - 14.2V you should charge just fine until the BMS shuts off the batteries.   If you have heavy gauge wires running back there, you may want to check that you don't pull too much current.    These batteries will happily charge at 1C, so 150A draw!   You would also need to size your BMS appropriately.
Another, more expensive but more elegant option is a DC-DC charger, which would both boost the voltage and limit the current.  You would want one that is adjustable for LiFePO4 voltages.
Edited by rando, 07 November 2017 - 03:22 PM.
  • 1
2016 Fleet Flatbed
2016 Toyota Tacoma
#27 cwdtmmrs
cwdtmmrs
  • 529 posts
Posted 07 November 2017 - 05:32 PM
Rando, thank you or the advice. I do have heavy gauge wires from the truck  I have added 4 gauge wires and left the original 10 gage wires in place as well. My alternator is not ECU controlled and does put out 13.9-14.2V/14.4V. It is 120 amp and can produce 60 amps at idle. I don't use much power normally and my 55AH Optima Yellow Top battery has served me just fine, but it will be 10 years old this Spring and I probably should replace it soon. Your DIY lithium pack looks like a fun project and could triple or quadruple my capacity for the same weight.
Do you have suggestions as to which DC-DC charger and BMS to use? Would you use larger gauge wire for the internal cells? I would also need a clean, sturdy way to hook my existing battery cables to the via battery posts or lugs.
Thank you so much for all of your information!
cwd
CWDT
#28 Vic Harder
Vic Harder
    Get's a "charge" out of camping!
  • 2,010 posts
  • LocationCalgary, Alberta
Posted 07 November 2017 - 06:11 PM
cwd,
With the 4 gauge wire and 14.4v output, assuming a healthy 40A charging current, you will see 13.6v or so at the batteries.  You should not need a dc-dc converter, just the BMS.
2006 Silverado 3500 ext cab 8' bed LBZ, FASS, EGT delete, 5" exhaust, FTE Resonator, MotorOps 50 HP Tow Tune
2005 Hawk Shell built the way I like it - SOLD
2012 ATC Puma (Grandby) shell - build started!
#29 rando
rando
  • 949 posts
  • LocationColorado
Posted 07 November 2017 - 06:25 PM
It is definitely a fun and satisfying project.
I have not used a dedicated DC-DC charger, so hopefully someone else can chime in with suggestions.
One idea I have had is to use on of the Victron MPPT solar chargers that I seem to always be talking about as a DC-DC charger.   The way to do this would be to buy the MPPT charge controller and buy a 12v - 24V converter and attach the output to the solar panel input of MPPT controller.
This would have a couple of advantages:
1.  If you get the SmartSolar version, you get bluetooth control and monitoring of the charger ,so you can adjust your set points and watch your battery charge from your phone/tablet in the cab of the truck as you drive.  If your battery is not easy to get to, this could be important.
2. If you hook up the camper to the load terminals of the charge controller you can also watch your consumption on your device, so it operates as a more detailed BMV/Trimetic.  The cool thing is that it gives you more than just the net charge/consumption, it gives you separate measurements of charge and discharge.
3. You get a built in low voltage / high voltage disconnect which will protect your batteries as a backup to the BMS.
4. If you ever do add solar, you are set up and ready to go - you could even have a switch to switch between alternator charging and solar charging using the same controller.
5. I think the cost would be about the same as a similar quality DC-DC charger.
I did rewire my camper so that the loads go through the load terminals on my new SmartSolar 100/20 for the reasons listed above.
2016 Fleet Flatbed
2016 Toyota Tacoma
#30 cwdtmmrs
cwdtmmrs
  • 529 posts
Posted 08 November 2017 - 06:48 PM
Vic, I am getting closer to 13.8-14 volts at the camper battery.
Rando, Thank you for the suggestions. You are correct in that I cannot get to the battery once the camper is mounted on the truck. I though about modifying the inside of the camper with a hinged lid, but it has never been an issue so not a priority. I'M not smart enough to use a smart phone! I'm not much of a tech type guy, I don't even own a TV and still can't keep my clock radio from flashing 12:00!  I don't foresee ever adding solar unless it is a very small portable just to keep up with the computer fridge fans when I am backpacking for more than a couple of days.
cwd
CWDT
Also tagged with one or more of these keywords: Lithium, LiFePO4, LFP, DIY, Batteries
