Kidde fire extinguisher recall
#11
Posted 05 November 2017 - 01:08 AM
#12
Posted 05 November 2017 - 02:44 AM
Interesting.
I attempted to use mine from the camper to put out a campfire in windy conditions that didn't seem to be improving and the extinquisher failed to operate. Hope I didn't chuck it but think I may have. Can't seem to find it in the shop.
Founder of D.E.R.P. Desert Exploration & Research Project. A camp proper is a nomads biding place. He may occupy it for a season or only for a single night, according as the site and its surroundings please or do not please the wanderers whim- Horace Kephart.
2009 4x4 Tacoma Access Cab-The Gini
2013 Silver Spur Finch Shell- The Oxcart/Gini's Burden-
#13
Posted 06 November 2017 - 02:38 AM
Edited by longhorn1, 06 November 2017 - 02:38 AM.
#14
Posted 06 November 2017 - 02:51 PM
I have two on the list, including the one from my '01 Hawk shell.
Just a few quick notes on filling out the claim form:
- I tried putting n/a in the date code field to indicate not applicable but the form rejected that as invalid. If your extinguisher doesn't have a date code, leave that field blank.
- The search function couldn't find the one from my kitchen when I entered model number 1A10BC. And it came back empty on a partial search for "1A". But when I thought to search for Kidde, the resulting list included an entry for "Kidde 1A10BC". If you can't get the form to accept your model number, you might try looking through the listings accompanying the annoucement for clues on how it might be listed in the database.
'01 FWC Hawk shell on a '13 Tundra Double-Cab + '19 Ford Transit van with Quigley 4x4 option
#15
Posted 06 November 2017 - 04:49 PM
I am assuming they won't want the old ones back - in which case I may have to do some fire extinguisher practice.
For sure it would be interesting to test them out. Worse than useless if they don't work.
Just a thought here ... My understanding is the dry chemical powder used in some types of extinguishers can settle over time, going from a loose powder into more of a solid mass. And we know vibration (think driving) can cause compaction. I've read the recommendation to, at least once a year, turn these dry chemical extinguishers upside down and tap the bottom of the cylinder with a rubber mallet to loosen up the contents. I do this occasionally with the 5lber I carry in the truck box. If I shake or tilt the bottle before and after I can "feel" the difference it makes to the flow of the powder within.
#16
Posted 06 November 2017 - 06:02 PM
My 2016 Four Wheel Camper provided extinguisher was involved in the recall.
Here are some direct links to help everyone out.
Plastic handle identification:
https://s3.amazonaws...ct ID Guide.pdf
Push button identification:
FAQ:
https://s3.amazonaws...ng to Kidde.pdf
Sign up for replacement:
(Select country then at the bottom of the page click the link for the type extinguisher needing replaced)
https://inmarmarketaction.com/kidde/
2016 Ford F150 SuperCab 4X4 Lariat 2.7 EcoBoost Engine
2016 FWC Hawk Front Dinette Silver Spur
#17
Posted 06 November 2017 - 06:54 PM
Guess I'll have to check this out. Between the house, different trucks, boat and camper I have a few of this brand of FE.
Edited by Squatch, 06 November 2017 - 06:55 PM.
#18
Posted 07 November 2017 - 07:02 PM
If you run dry chem I'd shake them once a month. One more thing that makes me glad I went away from dry chem.
#19
Posted 07 November 2017 - 08:27 PM
The Kidde website did not work for me. Plan B: Called their "Kidde Support Line" toll free number @ (855) 271-0773. The receptionist will take and enter your information (name, address, model/serial numbers and color) into their computer system. Done! You can expect your new fire extinguisher on your door step within 10-14 days.
Happy Trails...
#20
Posted 08 November 2017 - 09:20 PM
Both the ones in my boat, the one in my camper, 3 more in the house and garage. All on the list. Called the telephone number and got quick answer. They are sending out replacements.
