Ordering, tomorrow! 2nd battery option?
#1
Posted 14 December 2017 - 09:26 PM
My question is: What do you get with the 2nd battery option? Do they wire in a 2nd lead? Or do they just add a wire harness between the two batteries? What is the value of the 2nd battery option, besides another battery?
Finally pulling the trigger! Going big ... I was going w/Hawk but the 8’ Camper gives me & the Mrs. plenty of room to fight ... with our own neutral corners. A good buddy is an aluminum fabricator. I will post pictures if anything cool gets done.
#2
Posted 14 December 2017 - 10:29 PM
I am haunted by waters
#3
Posted 14 December 2017 - 10:36 PM
We ordered our FWC Grandby in Sept of 2016 and were able to delete the battery so that I could install two Lifeline 6 volt Golf Cart batteries. The wires were in place and the only thing special that I did was to change the wires between the two batteries to #4 wire.
The downside to doing this was that FWC really didn't check out the wiring and we later found the converter had not been hooked up properly to charge the batteries. Had we ordered a battery they probably would have been able to spot that in CQ.
BTW, Are you having FWC add the roof wiring for the solar panel?
#4
Posted 14 December 2017 - 11:27 PM
I had no problem ordering my Eagle shell with no battery. Did all my own wiring that way too. Ron
#5
Posted 14 December 2017 - 11:54 PM
When I discussed with Pete @ FWC he said that I would definitely want a second battery with the 130 Liter fridge that I am ordering my Hawk with. So I guess it depends on if you are getting a compressor fridge, and what size.
#6
Posted 15 December 2017 - 12:23 AM
Solar wiring for the roof & rear is also standard.
They are going back to less standard items, as per usual, for 2018.
Is the 2nd battery option just a battery?
#7
Posted 15 December 2017 - 12:51 AM
If you’re going to install a second battery, it would be best to ensure it’s the same mfr/type/age as the first. The easiest way to do that is to get it from FWC.
Did you look at ATC? Mandatory isn’t a big part of their vocabulary, flexible is...
#8
Posted 15 December 2017 - 01:59 AM
I'll second going with ATC, Four Wheel is getting out of control. Customer is number one in my book. Ron
#10
Posted 02 February 2018 - 05:41 AM
Just got a 2017 Fleet with a second battery and it is wired in parallel. Second battery and wires is all. Would be really easy to add a second if the first is already there.
