Solar Panel Mount on FWC Roof Question
solar renogy Fleet FWC roof rack
13 replies to this topic
#11 Josh41
Josh41
  • 152 posts
  • LocationMassachusetts
Posted 31 January 2018 - 10:28 PM
Unfortunately, Renogy's 150 still will not span the tracks.  So I will buy some Z or L aluminum at my local Metals Supermarket and install the 100W panel on the aluminum across the Yakima tracks. After reading more, it seems like 100W won't quite cut it between shade, angle, latitude, etc.  So another panel is in my future.
Here's the question: Does the other panel have to be 100W? Can it be more or less?  And, what about getting a fold-able panel for the second and plugging it in to the rear solar panel plug? If the fold-able gets full sun and the roof panel is shaded will it be a problem?
As an aside:
I found the wires needed in the battery compartment that come down from the solar plugs on roof and rear of camper, I hooked up a battery to the roof plug and identified the  + and - wires (they were red+ and black -) and the shielded end of the plug is the +.
Nissan Frontier 2016 CC LWB, 2" lift, tires, airbags and other stuff
FWC Fleet
Summers Off
#12 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,948 posts
  • LocationCalgary, Alberta
Posted 01 February 2018 - 03:12 AM
Sounds like you don't have a controller yet.  Which one are you getting?  Ideally, if using a PWM style controller, the two roof panels would be the same.  If MPPT style controller, you should hook them up in series and the max current of the two panels should be similar/identical.
  • 1
#13 rando
rando
  • 1,638 posts
  • LocationColorado
Posted 01 February 2018 - 05:07 AM
There are plenty of other panel suppliers besides Renogy - DMSolar has a 160w panel that will span the tracks, Eco-worthy also has a 160W panel that should span the tracks.   If you are planning on an MPPT charge controller (which you probably should), you could also consider 24V panels which come in larger sizes, many of which will span the tracks.  The only drawback with 24V panels is that it makes is harder to add a portable panel in parallel as it would also have to be a 24V panel.
2016 Fleet Flatbed
2016 Toyota Tacoma
#14 BobM
BobM
  • 730 posts
Posted 01 February 2018 - 05:28 AM
Here's how I mounted my Renolgy 100 watt. I bought a couple of aluminum angle and riveted them to the panel. I then mounted that setup to my Yakima racks:
https://youtu.be/zpgk5YocDyo
Also tagged with one or more of these keywords: solar, renogy, Fleet, FWC, roof rack
