Where is the best place to mount a camera to replace the stock tailgate cam on a Tundra? Mounting on the license plate provides little if any depth perception and the license plate lights blind it. Middle of the Hawk's door seems like the best spot but requires the wires to flex - not sure if that is a problem. Ideas?
Backup camera
#1
Posted 27 January 2018 - 03:08 AM
#2
Posted 27 January 2018 - 03:54 AM
I took a piece of aluminum flat bar, drilled holes to match and can install the camera in 5 minutes. There’s a hole in the body
about 1” x 2” to run the wiring through. Every other spot I tried to mount seemed to invite kicking the camera or exposing long lengths of wire.
#3
Posted 27 January 2018 - 12:56 PM
I placed about where Lobster1 did also but on my Superduty... works fine except when towing
#4
Posted 27 January 2018 - 09:23 PM
Jack, just above the license plate in the body of the truck there are 2 holes about 12” apart that accept an 8mm threaded bolt.
Lobster- That is exactly how I have the camera mounted now. It gets blinded by the license plate lights and doesn't provide the depth perception I need/want for backing into a trailer hitch. I'd like to get it up higher, but no place jumps out as a reasonable spot.
#6
Posted 28 January 2018 - 05:50 AM
Logical maneuver Captain.
Edited by cuervo, 28 January 2018 - 05:56 AM.
2017 Swift on a 2017 Tacoma
#7
Posted 28 January 2018 - 01:49 PM
Hey Jack
I bought this setup, but from a different vendor for only $150, cant find link now
Super easy plug and play install and works perfectly:
www.camera-source.com and search for your model towards the bottom
Follow My Shenanigans: instagram.com/campermccampface
#8
Posted 31 January 2018 - 11:03 PM
#9
Posted 01 February 2018 - 12:24 AM
I have the camera source one as well. Have it temporarily mounted to the license plate with their bracket and didn't really notice any real issues. I kind of thought the camera seemed to be better than the oem one. I will be moving it to the Hitchgate here pretty soon though.
#10
Posted 01 February 2018 - 02:24 AM
Thanks for all the great ideas. I have the camera source cam and will try the Velcro trick (abqbw).
