Yakima track bolts ?
19 replies to this topic
#11 penner
penner
  • 188 posts
Posted 21 March 2018 - 12:38 AM
Never got around to calling rack attack but I did call Yakima customer service. The guy there said they don't sell the nuts separately , they only come in with the pkgs with the towers. So I thought I would ask the guys at ATC and they said I will have to get them from Yakima. I'm baffled. Anyway , thanks Sage for the info on the TK 1 nuts.
#12 Rafter C
Rafter C
  • 76 posts
  • LocationGrass Valley, CA
Posted 21 March 2018 - 04:44 PM
https://www.etrailer...a/Y8810074.html
or
https://www.etrailer...ima/Y10156.html
Depends on what dimension you want....
'08 Dodge 3500, '11 ATC Cougar
Build Thread: http://www.wanderthe...r-build-thread/
Blog: https://raftercexplo...s.wordpress.com
#13 ETAV8R
ETAV8R
  • 906 posts
  • LocationRepublik of Kalifornia
Posted 15 May 2019 - 04:42 AM
I wanted to share my opinion of the Thule cam nuts. I ordered four of them for my Yakima tracks on my truck shell. Same tracks that I had on my Finch. Wish I had taken the chance earlier with these. They are so much easier than the square type track nuts. So simple to put in and take out. No removing the endcaps.
https://www.etrailer...e/853-2106.html
Founder of D.E.R.P. Desert Exploration & Research Project. A camp proper is a nomads biding place. He may occupy it for a season or only for a single night, according as the site and its surroundings please or do not please the wanderers whim- Horace Kephart.
2009 4x4 Tacoma Access Cab-The Gini
2013 Silver Spur Finch Shell- The Oxcart/Gini's Burden-
http://www.wanderthe...ory/#entry83606
#14 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,589 posts
  • LocationNortheast Oregon
Posted 15 May 2019 - 04:50 AM
Absolutely, that’s the only track nuts I will use. Holy catfish, they used to be 99¢.
ReRack has them for $1.99
https://www.rerack.c...uery=Track nuts
I am haunted by waters
#15 ETAV8R
ETAV8R
  • 906 posts
Posted 15 May 2019 - 04:20 PM
Have you ever had them fail?
One member on Tacoma World is stating he no longer uses them because they have become dislodged from the tracks more than once. I'm planning on mounting my shower tube to the tracks using these cam nuts.
#16 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,589 posts
Posted 15 May 2019 - 10:15 PM
No failures to date. I used loctite, but suspect it wasn’t needed.
#17 larryqp
larryqp
  • 299 posts
  • LocationFull-time RVer, anywhere USA
Posted 16 May 2019 - 12:09 PM
The A nuts are only $7.95 for eight thru eTrailer online.
With regards to having to remove the end caps, that really isn't a big deal. I placed 12 A nuts in each Yakima rail. I buy whatever size stainless bolt, and lock washer I need at the local Ace Hardware. I then mounted my solar panels, canoe racks, some tie downs and my fly rod holder. I will say that since I didn't mount everything at the same type I did need to unmount things at times to position the nuts where I needed them.
I still have a couple of unused A nuts in the tracks, just in case I think of something else to mount.
2016 F150, FX4, XLT super cab
2019 FWC Hawk Shell
2009 Ford Ranger 4x4, XLT, Supercab total loss on 7/30/19
2014 FWC Shell total loss on 7/30/19
#18 Bro_Raif
Bro_Raif
    Newbie
  • Pip
  • 1 posts
Posted 08 June 2019 - 06:24 PM
So to see if I understand what you’re saying here, do you install items directly to the track using these nuts without using the Yakima towers and crossbars? I am sure that part of that sentence includes terminology different than Yakima might use but hopefully it makes sense to the highly intelligent readers of this forum. :-)
#19 larryqp
larryqp
  • 299 posts
Posted 09 June 2019 - 12:23 PM
Yes, I have yakima towers etc for the yakima cross bars for carrying a canoe, lumber etc. But the rest of my "options" are mounted with stainless steel bolts directly to the "A" nuts in the yakima rails.
  • 1
2019 FWC Hawk Shell
#20 ETAV8R
ETAV8R
  • 906 posts
Posted 10 June 2019 - 08:43 PM
I had a failure of both the cam nuts used for my shower tube on my Yakima Tracks. Had to do an impromptu field fix and recently switched them for the square nuts but didn't load the shower tube with water to test them out.
