eyebolts pulling through wood
eyebolts mounting
10 replies to this topic
#11 ntsqd
ntsqd
    Custom User Title
  • 2,158 posts
  • LocationNorth So.CA
Posted 22 May 2018 - 03:40 AM
Plywood is strong, but it doesn't take concentrated loads very well - particularly in a mid-span like the pics above. They need to be distributed loads. I would move the eye-bolt over closer to the corner of the horizontal plywood that it is in, and the lower vertical plywood. Make 'L' shaped steel plates to lay over the corner on the inside and be bolted thru both plywood pieces. A plate on the outside would need to be thru-bolted to the inside plate for it to add any strength to the mount. Just captured there it does nothing.
Thom
Where does that road go?
Also tagged with one or more of these keywords: eyebolts, mounting
