Help with two 12 volt batteries (parallel)?
#1
Posted 30 August 2018 - 03:35 AM
#2
Posted 30 August 2018 - 03:57 AM
Do a search on wiring batteries in parallel, or series
This is one I found https://www.batterys...k-tutorial.html
You said a smaller wire that sound strange as the load carrying wires are normally the same guage if your not sure you might want to seek a rv repair center to ask for assistance.it could be very dangerous to short the battery terminals.Hope this helps.
Russ
Edited by CougarCouple, 30 August 2018 - 04:01 AM.
#3
Posted 30 August 2018 - 04:03 AM
#4
Posted 30 August 2018 - 04:08 AM
No. between batteries should be pos to pos. neg to neg.
So there should have been 2 short wires plus the pos and neg wires to camper system
#5
Posted 30 August 2018 - 04:11 AM
are you sure both batteries are 12v ? each battery should have 6 cell caps if 12v
well you charged them so would know ...
Edited by klahanie, 30 August 2018 - 04:11 AM.
#6
Posted 30 August 2018 - 04:18 AM
#7
Posted 30 August 2018 - 04:20 AM
#8
Posted 30 August 2018 - 04:25 AM
I just bought this hallmark and owner says they are 12 volt BUT... they only have 3 cell caps. Does that change the wiring if 6 volts instead of 12 ?
yup.
it matters, per link from Russ
2x 6v should be like this...
so no missing parts
all is well
but how did you charge them ? charger have auto select for charge voltage ?
#9
Posted 30 August 2018 - 04:31 AM
Take a picture and show us what you have. Use a volt meter and see what the voltage is on each battery. If 12 volt wire in parallel. If 6 volt wire in series.
Patrick
2015 FWC Hawk Flatbed
#10
Posted 30 August 2018 - 04:34 AM
