A friend and member here (TT) replaced his with stainless several years ago, zero issues and screws look like new...
I have been replacing the screws in my camper with stainless when needed or adding mods,used sealant to prevent water intrusion. After 5 years there is no visible corrosion...
as above, a lot of people report success with stainless screws based on the absence of corrosion on the screw head.
my understanding is any corrosion would be at the point where the metals meet (assuming conditions were right for the corrosion to occur) which means its possible for the stainless heads to appear completely corrosion free but the aluminum around the screw hole to be in very bad shape? not saying their screws aren't doing the job... just that they are not measuring success in the right way.
i appreciate the comments and have enjoyed the discussion. i haven't ordered the new screws yet but will very soon now as the camper is going into the garage for the winter shortly and i am leaning toward either being the guinea pig for the aluminum screws or going with zinc plated screws with EPDM washers (thanks for that Craig).
posters have commented that "aluminum isnt as strong as steel." i think we all agree on that but the question here isn't if aluminum is as strong as steel but rather if its strong enough and as i said i am not planning on using them for anything structural like jack brackets/strut mounts/etc. i don't need to kill a mouse with a shotgun if i mousetrap will do fine.
the strategy with the zinc screws is really to let the plating on the screws corrode over time (probably very very slowly with zinc plating, EPDM washers and sealant coated threads) and replace them down the road again in the name of preserving the aluminum frame.
wow am i really getting this into camper screws?
