Leveling blocks?
38 replies to this topic
#1 Bjammin
Bjammin
  • 34 posts
  • LocationPacific Northwest
Posted 04 November 2018 - 03:17 PM
I was wondering what folks use to level campers on uneven ground.  I've got a couple of old 2 by 6 boards, but they really only work in one and a half inch increments.  There must be a better way.
Edited by Bjammin, 04 November 2018 - 03:17 PM.
#2 fish more
fish more
  • 795 posts
  • LocationSierra Foothills
Posted 04 November 2018 - 04:14 PM
ROCKS !!!!
#3 EDR
EDR
  • 177 posts
  • LocationSE WA
Posted 04 November 2018 - 04:56 PM
I’ve used Lynx Levelers for the past 20+ years.
Simple, durable and lightweight.
2007 FWC Hawk
#4 Mark G
Mark G
  • 132 posts
  • LocationMeadow Vista, CA
Posted 04 November 2018 - 05:26 PM
I use the Lynx also but these look interesting and are on my wish list:
https://www.amazon.c...lv_ov_lig_dp_it
#5 larryqp
larryqp
  • 299 posts
  • LocationFull-time RVer, anywhere USA
Posted 04 November 2018 - 05:57 PM
I use 2x10s which are about 2 ft long, I beveled one edge and glued 1/4 ext plywood to top surface, to prevent splitting. I also carry a number of 2x4s. Therefore I can use just the 2x10 for an 1 1/2 rise, or place the 2x10 as a ramp on the 2x4, thereby having a 1 1/2" ramp up to 3", place two 2x4s and your ramp goes from 1 1/2" to 4 1/2". I think you get the idea.
Without the plywood the ramps will eventual crack, they still crack with the plywood but don't fall apart.
2016 F150, FX4, XLT super cab
2019 FWC Hawk Shell
2009 Ford Ranger 4x4, XLT, Supercab total loss on 7/30/19
2014 FWC Shell total loss on 7/30/19
#6 DavidGraves
DavidGraves
  • 1,267 posts
Posted 04 November 2018 - 06:29 PM
I just use whats around where I am camping....don't mind a little uphill for pillows.
We sleep crossways one up and one down.
David Graves
#7 ntsqd
ntsqd
    Custom User Title
  • 2,881 posts
  • LocationNorth So.CA
Posted 04 November 2018 - 06:53 PM
We have these: https://www.amazon.c.../dp/B001V8LQ2G/
NOT recommended. The interlocking feature is nice, but the slots on the bottoms are thin enough that pea gravel sized rocks get stuck in them and then they don't interlock.
Thom
Where does that road go?
#8 Ronin
Ronin
  • 934 posts
  • LocationPNW
Posted 04 November 2018 - 07:11 PM
I use 2x6's , 2-20" long and 2-16" long. just stack them as needed with a 4" gap at the end to create steps. If I need more height a rock or chunk of firewood usually does the trick. I also have a couple of short 4x6s I use for my floor jack that could be used if there's nothing else around.
2019 Tundra 2019 Panther Shell
#9 klahanie
klahanie
  • Validating
  • 932 posts
  • LocationSW BC
Posted 04 November 2018 - 07:38 PM
I try to use what's on site, rocks, firewood, branches etc. But also carry various lengths of 1" plywood cut 11" wide x 8,10,12 etc. I found that 2x s can split, at least the lumber I've used. And the ply makes a great jack base when off pavement and jack stand base at home on grass.
Always like to chock a wheel or two when using a tall leveler, I guess 'cause it's never really level  :ph34r:  Some folks carry a bubble level for precision, adjust tire pressure etc.
#10 LiveLifeNow
LiveLifeNow
  • 62 posts
Posted 04 November 2018 - 09:40 PM
In my experience, Lynx levelers last longer than Camco levelers.
