Leveling blocks?
38 replies to this topic
#11 JaSAn
JaSAn
    Grumpy Old Man
  • 1,105 posts
  • LocationMinnesota
Posted 04 November 2018 - 10:31 PM
I use the yellow 'lego' blocks.  Pack more compactly and are much lighter than the 2X6s I used before.
Renovating Skoldpaddan
2012 Ram 2500 4X4
1951 Dodge Power Wagon
#12 PaulT
PaulT
    Need gumbo
  • 2,611 posts
  • LocationHillsboro, Oregon
Posted 04 November 2018 - 11:59 PM
I use these also, but carry several boards to go on the ground to reduce the damage caused by rocks on the bottom unit. A board also reduces the bottom one’s tendency to sink into soft earth.
#13 longhorn1
longhorn1
    Ouch, that stings!
  • 2,826 posts
  • LocationCarmel, Indiana
Posted 05 November 2018 - 12:28 AM
Lynx Levelers
http://texaslonghorns01.blogspot.com/
Ford F-250 Long bed, 2014 Grandby
#14 Optimistic Paranoid
Optimistic Paranoid
  • 213 posts
Posted 05 November 2018 - 01:04 AM
I try to use what's on site, rocks, firewood, branches etc. But also carry various lengths of 1" plywood cut 11" wide x 8,10,12 etc. I found that 2x s can split, at least the lumber I've used. And the ply makes a great jack base when off pavement and jack stand base at home on grass.
Always like to chock a wheel or two when using a tall leveler, I guess 'cause it's never really level  :ph34r:  Some folks carry a bubble level for precision, adjust tire pressure etc.
The trick to using 2X lumber is to screw two pieces together with the grain at right angles.  That way they really can't split under any REASONABLE amount of weight.
Regards
John
Rule #1 For Wandering The West: DON'T FEED THE VULTURES!
I Don't Like To Make Plans.  They Cause The Word "Premeditated" To Get Used In Court.
My Body Is A Temple!  Ancient, Falling Apart, Probably Cursed . . .
#15 rubberlegs
rubberlegs
    curmudgeon
  • 564 posts
  • LocationEverett, WA
Posted 05 November 2018 - 01:18 AM
Using my iPhone level app.
Tacoma/Fleet 2018.
#16 camper rich
camper rich
  • 357 posts
Posted 05 November 2018 - 05:56 AM
The thing I use most to level is a short square nose shovel. Generally, when camping on sand or dirt, it's much easier to dig a shallow hole for 1 or two wheels. If you dig too deep, you can always fill it back in a little. I do carry a couple of 18" long 2 x 6 pieces for hard surfaces, or use rocks.
  • 1
#17 trikebubble
trikebubble
  • 273 posts
Posted 05 November 2018 - 08:18 PM
I usually go with the yellow leveling blocks first. I've also used my Maxtrax for leveling, and will adjust my airbag pressure from side to side to help level out as well.
#18 Advmoto18
Advmoto18
  • 1,083 posts
  • LocationCoastal Low Country, SC
Posted 05 November 2018 - 10:07 PM
Lynx, but also carry scrap 10" LVL beams cut into 10" x 10" squares.
South Carolina Low Country.
#19 gaylon
gaylon
  • 176 posts
  • LocationBoulder Creek
Posted 06 November 2018 - 02:26 AM
I use these - the yellow stepped ramps from Camco.  If I need a third wheel lifted, I use a red plastic hi-lift jack plate I carry for jacking.
https://www.amazon.c...=leveler blocks
2015 Hawk on a 2016 Tundra TRD Pro
#20 Montreat
Montreat
  • 65 posts
  • LocationNorth Carolina
Posted 06 November 2018 - 12:03 PM
I use the level trex blocks and have been happy with their strength.
https://www.amazon.c...0?ie=UTF8&psc=1
Montreat 2015 Fleet 2015 Tacoma 4wd
