Looked around the forum but couldn't quite find any insight. I have my camper off in the garage for the winter (first winter with new 2017 hawk). I recently looked at my Victron Control app and noticed a low voltage warning. I plugged in the camper to shore power and 3 days later I still am getting the same warning. State of charge says 100% and voltage readout is at 11.71. Nothing has changed in the 3 days of being plugged in. Voltage won't go up and warning still on. Wondering if if I should lower my low voltage warning, currently at 11.9, which was what the factory setting was. 2 AGM 79AH batteries. Also curious with camper off and battery temps at around 39 degrees should I be expecting different results that I would see in the summer? Any insight on best way to maintain proper charge during the winter? I live in Tahoe so temps in the garage will be fairly low most of the winter.
Thanks
