Can it be put in washer and dryer, or does it need to be taken to a cleaners, or dry cleaned?
thanks!
Posted 12 December 2018 - 01:46 PM
thanks!
https://no-destination.org/ .:. https://razorgirls.org/
2014 Tacoma DCLB + 2015 FWC Fleet
Posted 12 December 2018 - 05:06 PM
Dawn...
Arctic Pak material is almost identical to some car covers...here is a "how to clean" ...I have had such a cover for decades and it looks and feels just like the thermal liner in my Hawk..these directions are common sense stuff...mild detergent, cold water, air dry...I would first call FWC and ask them about cleaning the Arctic Pak
Phil
Cleaning
All of our covers are easy to wash. For a light hand wash, install the cover and spray the it with a water hose. Dilute a mild liquid detergent, like Woolite, in cold or warm water and lightly cleanse your cover with a sponge. Feel free to clean the inside of the cover by installing the cover inside-out on your vehicle.
For a deeper clean, such as to remove tree sap or bird droppings, use a large commercial washer and set it to a "delicate" cycle to avoid causing any rips or tears in the fabric. Using an at-home washer is not big enough to clean your cover properly. When washing your cover, we recommend using a delicate soap such as Woolite. Do not wash your cover in hot water, as this will cause shrinking. Finally, to preserve your cover’s water resistance, we recommend running your cover through multiple rinse cycles.
Once your cover is washed, DO NOT place the cover in an automatic dryer, as this may cause the fabric to shrink or melt. If possible, we suggest air drying your cover at all times.
Edited by Wallowa, 12 December 2018 - 05:06 PM.
Posted 12 December 2018 - 06:08 PM
Edited by veryactivelife, 12 December 2018 - 06:12 PM.
Dean and Mary
2015 RAM 2500 Cummins with 2015 Four Wheel Campers Hawk flatbed
VeryActiveLife on Facebook, instagram & YouTube
Posted 12 December 2018 - 06:27 PM
What's the "bathtub" thing you mention?
(sadly, my house does not have a tub )
Thanks both of you!
Posted 13 December 2018 - 01:18 AM
I wouldn't recommend 303 for spot cleaning because the thermal pack is made of Olefin, not PVC like the pop-up material. Ideally, you want all of the cleaning product you use to be rinsed away so that the breathable nature of the Olefin is preserved.
Posted 14 December 2018 - 02:05 PM
Thanks both of you!
Dean and Mary
