I saw this and bought one to see how it works...it does. My only concern was the stress it would put on the U bolt catch. The physics of it does not so much pull down as push in as it is a lever. If the screws are robust it should be okay. I am 165 lbs. and my wife "less" :-) ... we are 5'8" and 5'2" so this is a great help in the front when tying down the 2 canoes. Perhaps too, when opening the Batwing awning we hope to get this year. Anyone tried one of these? The door shot is a bit blurry so will take another shot when the temperature goes back above zero!
#1
Posted 23 January 2019 - 02:23 PM
#2
Posted 23 January 2019 - 02:59 PM
Looks neat.
Do you have the web link of where you purchased it?
Or, at least what the thing is called?
#3
Posted 23 January 2019 - 04:55 PM
Sunman2003 Four Wheel Camper -Hawk
2023 All Terrain Camper - Panther 2006 Toyota Tundra Double Cab Limited 4WD
2017 Toyota Tundra Double Cab Limited 4WD
#4
Posted 23 January 2019 - 05:08 PM
Patrick
2015 FWC Hawk Flatbed
#5
Posted 23 January 2019 - 05:39 PM
#6
Posted 23 January 2019 - 06:44 PM
There was a discussion of these on another forum with slightly mixed opinions:
https://www.thesamba...of step&start=0
2016 Fleet Flatbed
2016 Toyota Tacoma
#7
Posted 23 January 2019 - 07:24 PM
Neat step/tool. Can be used as a safety hammer.
Some of the higher priced ones have little gripper teeth.
#8
Posted 24 January 2019 - 12:33 AM
Russ
#9
Posted 24 January 2019 - 02:17 AM
The problem for me is the camper roof is not on the same vertical plane as the door frame anchor. This would have me leaning backwards, not a positive position for me. Also some door anchors are posts.
Russ
Bingo...... as some might also experience.
Patrick
#10
Posted 24 January 2019 - 02:29 AM
My wife got in on the Kickstarter for this. She uses it and really likes it.
2005 Tundra 2013 Ocelot "Ridiculously comfortable"
2021 Tundra 2022 Cougar Shell Built Out "Even more ridiculously comfortable"
