The wooden floor is a place where soft wood/rot can occur anywhere in the floor and more worrisome, where the floor is joined to the sidewalls. Horror stories about guys leaving the Alaskan on the jacks with the floor unsupported ended with the floor falling out of the lower section have been posted.
I would suggest that if you have a bare frame as you suggest, that water will make its way to the floor and floor/sidewall joints and that would be a very bad thing to do. Why not put crossmembers every two feet and then fabricate a very THICK plywood "floor" to the frame to support the Alaskan as much as possible and add "ribs" running fore and aft to keep airflow and alleviate moisture? You can read here how guys have either waterproofed the bottom of the Alaskan or used a cushion of some kind to shed water.
You may also want to actually weld in supports running fore and aft that the lower section can put some of the weight on if padded to prevent damage and then secure the lower section to your vehicle frame addition. All this may sound like overkill, but its easier to build preventative fixes to the vehicle than to find the unsupported floor is failing!
Remember....it is WATER that is the biggest enemy to the Alaskan and that includes not only the roof, windows, doors and seams, but the floor.
Thank you for the reply, PR.
I’m thinking I painted an unclear picture of the plan I have in mind: the floor of that camper will in no way be unsupported. I’m only trying to establish whether three joists on 24’s across, or one longitudinally would be the most effective. At this point I’m leaning toward 3 (or more— I have a bunch of 1x3 heavy wall tubing to work with) across. As understand it, the floor is 3/4 plywood, so 24” joist centers should work just fine. Most residential floors I’ve seen or built are on 24’s.
I’m a co-owner of a rain gutter company, so I’ve seen the effects of trapped water on fascia & soffit many times. We’ve made a lot of money correcting the effects of it, and that’s why I’m going to stay away from doubling up the plywood on the underside of the camper. I gave the idea some thought months back but dismissed it because it sounds like a 4x8-foot water trap to me. I will, however, go with your waterproofing idea & coat the lower section of the camper with some sort of coating. Any recommendations?
As I understand it, you’re suggesting additional support where the truck bed rails would normally be? That area will be occupied by tool boxes, and besides, as I understood it, an Alaskan camper is supposed to be supported solely by the floor, isn’t it?
As far as mounting this assembly to the truck frame, my inclination is rubber mounting it with 1/2” bolts. We haven’t really got the details ironed out yet, but once the subframe is built, we can mock it up easily enough.
Thank you for the suggestions— you pretty much convinced me joists running side-to-side are the way to go.
