satellite antenna question
4 replies to this topic
#1 penner
penner
  • 188 posts
Posted 21 February 2019 - 11:50 AM
Hi. I have my ATC mounted on a 2017 Silverado extended cab. Going certain directions my satellite radio loses reception. Anyone have a suggestion on how to fix this problem. The only reason I subscribe to satellite is for my long trips with the camper . Thanks. Glen.
#2 shellback
shellback
  • 336 posts
  • LocationWagontown,PA
Posted 21 February 2019 - 02:07 PM
Glen, I guess you have the longer cabover. On my previous camper with the long cabover I lost reception, but with my 4wc, and the 2 foot cabover, no problem. On my previous Dodge truck I was able to use a remote satellite antenna, but it was easy access to plug it in. Not so easy with the Chevy. If you can figure out the access for a remote antenna, let me know. I'll send you a free magnetic one.
Edited by shellback, 21 February 2019 - 02:08 PM.
#3 PaulT
PaulT
    Need gumbo
  • 2,612 posts
  • LocationHillsboro, Oregon
Posted 21 February 2019 - 03:31 PM
You're not the first with this problrm here. Search for "site:www.wanderthewest.com satellite antenna" and see if one of the tthreads has a possible solution for you.
Good luck.
#4 penner
penner
  • 188 posts
Posted 22 February 2019 - 11:15 AM
Thanks for the replies Guys. Ron, thanks for the offer, it doesn't look like I can access the Chevy antenna to easily. Might just looking into a portable unit and going with a magnetic antenna.
#5 smlobx
smlobx
    Lost again
  • 1,529 posts
  • LocationNorth Carolina
Posted 22 February 2019 - 01:10 PM
This is also a problem with Fords with a long cab over configuration like we have.
On another forum the consensus fix was to buy another OEM satellite antenna and mount it on the plastic cowling at the base of the windshield. You then snake the wire through the firewall and plug it into the wire going into the gps/radio unit by unplugging the original wire coming from the roof.
This has the effect of moving the antenna forward about 15 inches or so and has minimized the problem. Of course the further north you go the more this becomes an issue so in northern Canada and Alaska you will probably not be able to receive the signal.
If you need to I can take a picture of mine...
Eddie
KO4CPL
