Extra wires in 2015 hawk
8 replies to this topic
#1 Stephenjd
Stephenjd
    Newbie
  • Pip
  • 1 posts
Posted 11 March 2019 - 12:41 PM
Have a shell with heater, stove and two batts. Doing some work and opened panel on inside by propane box and found two green wires? Any idea what they are for?
Stephen
#2 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,584 posts
  • LocationNortheast Oregon
Posted 11 March 2019 - 01:43 PM
Possibly/probably solar pre wire. If so, the other ends are in the roof. Call FWC to get details.
I am haunted by waters
#3 NorCalSteve
NorCalSteve
  • 198 posts
  • LocationChico, CA
Posted 11 March 2019 - 03:01 PM
On off switch for fridge fan? On my 2012 Hawk, it was an option. I added computer fans later.
Hawk on a 1994 Silverado 2WD pickup
#4 roverjohn
roverjohn
  • 129 posts
  • LocationKANSAS CITY
Posted 11 March 2019 - 03:40 PM
I'll guess they are for connecting to propane tank if yours is equipped with floats but only because of where you found them and they don't seem to be polarized.
#5 Ace!
Ace!
  • Gone Traveling
  • 530 posts
  • LocationSo. Oregon
Posted 11 March 2019 - 06:06 PM
Green means go.  They must be go wires.
#6 Stan@FourWheel
Stan@FourWheel
  • 2,376 posts
  • LocationWoodland, CA
Posted 11 March 2019 - 07:11 PM
Without going to the shop to ask the guys on the line, my guess is that it is pre-wiring for the Rear Flood Light option.
Woodland, CA 95776
www.fourwh.com  ---  e-mail = stan@fourwh.com
#7 pvstoy
pvstoy
  • 2,770 posts
  • LocationCarson City, NV
Posted 11 March 2019 - 09:09 PM
Looking at where they are and that it looks like a switch could be installed to complete a circuit. It could be for the flood lights switch. The ends look like it has spade terminal and slide onto a switch. Use a meter and OHM check the wire at the fuse block location.
Edited by pvstoy, 11 March 2019 - 09:10 PM.
Patrick
2015 FWC Hawk Flatbed
#8 Beach
Beach
  • 866 posts
Posted 12 March 2019 - 02:18 PM
Have you checked them with a meter? Check to see if they are switched or are they have continuity to ground or have voltage if switched.
#9 Offgrid4Two
Offgrid4Two
    Newbie
  • Pip
  • 9 posts
Posted 13 March 2019 - 10:46 PM
They are more than likely pre-wiring for flood lights. Most of the green wiring is lighting related.
