For Sale - 2016 Hawk Four Wheel Camper Riding on a 2012 RAM 2500 presently. It slides into the bed of a pick-up truck. The truck is not included.
Roll over couch seating
Deluxe fabric cushions
Formica counter top
Dual Batteries w/Separator
Dual 10 Lb. propane tanks
160 Watt Solar Panel w/Charge Controller
Furnace system (Cabinet/Thermostat/Propane)
Mechanical camper jacks-4 corners
Dining Table
1 Fantastic Fan
Extra Roof Vent
Yakima tracks
Exterior lighting
Privacy Curtains
Gas Strut Roof Lifts
12 Volt Receptacles
One of the pics shows a crescent size ding in the cabinet
$15000.00 will consider delivering depending---
We have had two of these-the main thing is that broadly speaking this Hawk will fit on a short bed pickup with a 6'5" bed if the bed side walls are 21" tall or less. The portion that sits in the bed is 23" =/- tall so if you have a 21" bed you will have 2" of clearance. The first one we bought was on 2012 Tundra and it had a bit over an inch of clearance-It was fine. If you have a bed with a bed depth that is higher than 22"-23" you will need to put something in the bed so the camper will be above the bed side rails by a couple inches
Thanks for your inquiry,
Reggie
Located in Winterville, Georgia
Email is dogsgo2heaven@gmail.com
Edited by whitedog9, 12 April 2019 - 08:45 PM.
