Nice lighting upgrade. I'm not sure what the bugs are like where you camp, but I find amber lights attract them less.
2001 Eagle 4 Wheel Camper- Refresh
#21
Posted 02 May 2019 - 06:40 PM
#22
Posted 02 May 2019 - 07:32 PM
Good call. Bugs vary on spots and time of year for us, but always want to minimize. The lights came with amber covers too. Wasn’t sure what to do with them, but will find to find a way to stash them somewhere to see if that helps.
#26
Posted 27 May 2019 - 08:10 AM
Nice framework for the new bench. What storage plans do you have for the framed-in places under the bench? I generally try to keep the floor space as flexible as possible, partly because there isn't much room in the Eagle to begin with. I removed the old frame from under my bench and instead have a few legs to hold the bench up. That way I can easily slide a few plastic containers under the bench and a porta-potti near the rear door. Sometimes I push the bench up 90 degrees so that I can put bicycles in the center. The legs on the bench need to fold flat, otherwise they would be in the way when the bench is raised.
#27
Posted 27 May 2019 - 01:03 PM
Will end up enclosing the entire frame. Going to add a folding “sleeve” with legs to extend the bed out another 8-10”. Had to sacrifice the storage to make sure I had a stable bed platform. For storage I have used bins that i keep in center isle of camper when on road and then move to cab of truck with camping. Not turn key, but need the bed. Tried to convince my wife the kids can sleep in a tent outside, but you can see who won that battle.
#28
Posted 28 May 2019 - 04:49 PM
The propex HS 2800 heater is installed. Need to get some tools to get the gas line finished up so I can test.
Couple thoughts. Should have went with the smaller unit HS2000. Had to use a lot if space to accommodate the venting.
The goal of this was to build two boxes. One that contains the exhaust and intake. The second is platform the heater.
The top will serve as bench for cooler/stove/bins.
