Got our new Grandby. The stock USB charging port is on the drivers side, under the kitchen counter. That means all your stuff to be charged ends up on the kitchen counter, dinette seat or just hanging down.
Sure wish it had a charging port on the other side. . . . .
Humm, FWC pre-wires for options not installed. LED side lights or maybe even a fan for an LP refer. If you have a compressor fridge, you might not need that fan/circut.
Pick up an inexpensive ($16) USB charging hub on Amazon. LINKY
Cut the end off and add a male & female spade connector.
Find the LED side light wiring not used/ordered as an option.
Make a jumper.
Jumper the wires together. Or, get a switch from FWC that fits the panel. I'll do that later.
Poke a fish wire through the silicone for the reefer wiring.
Grab the end in the cabinet and fish it up through the other hole near the reefer AC outlet.
Drill a hole between the two upper cabinets.
Waa Laa!!! USB charging on the passenger side. In the cabinet or above.
