another drain valve replacement
16 replies to this topic
#1 bfh4n
bfh4n
  • 235 posts
  • LocationLovingston, Virginia
Posted 20 April 2019 - 04:50 PM
I guess everyone has to replace the original cheap plastic drain valve eventually. I chose this one because I want to be able to attach a hose. It sticks out far enough that the door was going to hit it, so I extended the door bumper.
2014 silver Fleet front-dinette
2007 Tacoma Access Cab 4WD TRD V6 6-speed
#2 Conestoga
Conestoga
  • 38 posts
  • LocationAlameda, Ca
Posted 20 April 2019 - 05:38 PM
Like your setup better than what we did. Could you provide more details on what pieces you used, where they were acquired and any special tricks for install...both on the valve and the bumper.
Thanks
#3 Missing Link
Missing Link
  • 507 posts
  • LocationFoothills of the Southern Sierra
Posted 20 April 2019 - 06:38 PM
I too would be interested in that information, as the handle on my original one just broke.  Thanks.
2017 F150 with 2017 Hawk
#4 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,959 posts
  • LocationCalgary, Alberta
Posted 21 April 2019 - 12:59 AM
Looks similar to mine... I like the blue handle better though!
#5 bfh4n
bfh4n
  • 235 posts
Posted 21 April 2019 - 02:08 PM
I got the valve from McMaster-Carr Supply. It's brass, quarter-turn. (Listed in the online catalog under "Hose Bibbs") .The blue handle was a plus! The mounting holes had the same spacing as the original valve. I used stainless sheet metal screws. The brass pipe thread-to-hose fitting is McMaster 5346K21. (1/2" male pipe thread, 3/8" hose.)
I had to orient the hose clamp just right to get it to go back into the camper wall.
I made the bumper extender from a short piece of 3/4-inch PVC conduit. (PVC 3/4" water pipe is the same size, but white.) I got nice square ends by cutting it with a chop saw. The notches were easy to rough in with a hacksaw and trim with a utility knife. I used acetone to clean off the writing. I used a longer screw and put a 1-inch diameter fender washer between the bumper and the PVC part.
The whole project took less than an hour.
Edited by bfh4n, 21 April 2019 - 02:28 PM.
  • 1
#6 craig333
craig333
    Riley's Human
  • 8,017 posts
  • LocationSacramento
Posted 21 April 2019 - 11:44 PM
My plastic valve was still working when I replaced it. The motorcycle tank valve lasted a year before it completely froze up.
#7 muttmaster
muttmaster
  • 174 posts
Posted 25 April 2019 - 08:32 PM
Can you measure the distance from mounting surface to outer hose thread. My Granby’s outlet is located on the right side of the propane compartment door and I am not certain this Stillcock will allow my camper door to close and latched to the newer door hold down lever. Nibco bib diagram does not show the dimension I need, and I don’t remember my trigonometry at all. I think I only have about two inches clearance when the door is latched open.
I suppose hose connection would be nice, but realistically, the 3/8” hose only allow so much flow. Not enough to wash my truck anyway. Why do they call it a Stillcock anyway. Because it only trickles?
Edited by muttmaster, 25 April 2019 - 08:51 PM.
#8 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,959 posts
Posted 26 April 2019 - 03:23 AM
That's why I plumbed mine into the pressure side of the water pump.  I have pressurized water outside!  And it makes emptying the tank faster too!
  • 1
#9 craig333
craig333
    Riley's Human
  • 8,017 posts
Posted 26 April 2019 - 04:41 PM
Does it still work with the pump off?
#10 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,959 posts
Posted 26 April 2019 - 06:07 PM
very slowly , as per normal
EDIT --> NO, it doesn't, which is kind of nice, since the tank won't drain accidentally... you have to turn on the pump first to get water out of the outside spigot.
Edited by Vic Harder, 24 July 2019 - 04:29 PM.
