If I can ask a stupid question, I am going to add a second battery in parallel, how do I add a shunt for each battery, and how will it know which battery it is seeing if both are connected?
#21
Posted 19 August 2019 - 04:03 PM
#22
Posted 19 August 2019 - 04:36 PM
#23
Posted 19 August 2019 - 05:04 PM
So I know the charge on each battery individually
#24
Posted 19 August 2019 - 05:53 PM
#25
Posted 19 August 2019 - 07:15 PM
Thats the problem, cannot get a real sense of each battery, idealy they should be the same, but if not how would I know?
#26
Posted 19 August 2019 - 08:21 PM
#27
Posted 19 August 2019 - 09:06 PM
This is a great question. The BMV has an option for "mid point" voltage testing, but that only works for series connections.
As Buckland suggests, the two batteries should be identical in makup/brand/age. To use the shunt as intended, I would suggest using a buss connection for both batteries to ground to, and from there go to the shunt. You will NOT be able to see individual SOC for each though
#28
Posted 19 August 2019 - 09:40 PM
For a short time, it bothered me that this info was unavailable, but the cost of obtaining it is well past the point of diminishing returns, IMHO.
If it is a concern, attach the positive lead from solar & load on one battery, and place the negative lead from the shunt on the other battery, swallow hard & enjoy your camping. Life keeps getting shorter.
Also tagged with one or more of these keywords: shunt
Trucks, Campers, Gear Forums →
Electrical, Charging, Solar, Batteries and Generators →
Truck Camper Shell - AGM Batteries InstallStarted by FoxenTec , 10 Oct 2020 ground, return, shunt |
Truck Campers →
Four Wheel Camper Discussions →
Solar for the HawkStarted by Hobart78 , 03 Jan 2015 shunt, tri metric, solar panels and 1 more... |
