What battery are you using with your solar system?
Any info appreciated.
Posted 11 June 2019 - 09:59 PM
Ford F150 super crew, ATC Ocelot shell, Icom 706MKIIG, AC6GD
Posted 11 June 2019 - 10:58 PM
Posted 12 June 2019 - 01:22 AM
I've seen that thread but that doesn't answer my question.......
Posted 12 June 2019 - 02:00 AM
I am haunted by waters
Posted 12 June 2019 - 02:15 AM
What is it that you want to know? Brand? Size? Type? Form factor?
Brand - I use and recommend Rolls/Surrette batteries. A reputable brand will include spec sheets on their batteries, with specific voltages, temperature coefficients, charge cycles, etc. Trojan have been good in the past too.
https://rollsbattery...tery/s6-275agm/
Size - Depends on your usage patterns. I use 250 AH batteries in mine. Sized to be able to keep me running for 3 days without charging.
Type - AGM for me... and that is as opposed to FLA (flooded lead acid) or LiFePo. The AGM's are relatively maintenance free and don't gas off much. Also supposedly better able to handle vibration than FLA.
Form Factor - Type GC2 (Golf Cart 2). Most people think "golf cart" means FLA 6v. GC2 is a size standard, not voltage or cell type.
I hope that helps
Posted 12 June 2019 - 11:28 AM
i have two 12 v Renogy, 100 Ah AGM batteries, powered by 175 watts of solar panels. (1x 100 w and 1x 75 watt)
2016 F150, FX4, XLT super cab
2019 FWC Hawk Shell
2009 Ford Ranger 4x4, XLT, Supercab total loss on 7/30/19
2014 FWC Shell total loss on 7/30/19
Posted 13 June 2019 - 07:51 PM
I don't require many amp hrs for my style of camping, plus I run the fridge on propane. I have a 55ah blue top optima battery with a 60 watt panel. Optima blue tops are dual purpose and not a deep cycle battery in the truest sense but it does what I need.. I got 5 years out of the first one before it died due to a malfunctioning solar controller.
Edited by Beach, 13 June 2019 - 07:52 PM.
Posted 15 June 2019 - 01:11 AM
I use two Lifeline GPL-4CT 6V 220 Ah batteries (66 lLbs each) connected in serial producing 12V 220 Ah which provide about 110 usable Ah. The batteries and charge /monitoring electronics are under the couch in the camper.
I have 200 W of Solar panels on the camper and use a Victron solar charge controller and a Vicrtron battery monitor both having bluetooth so I can remotely monitor the Solar charging and the batteries as well as the history of the battery charging/discharging from my iphone.
Regards,
Craig
Edited by ckent323, 16 June 2019 - 04:20 PM.
