Gas vs Diesel
#1
Posted 13 July 2019 - 01:53 PM
What are your opinions? Get a bigger gas tank? Switch to diesel? Ford ecotec? What are you driving?
2016 Alaskan Camper i.e. best decision I've ever made
#2
Posted 13 July 2019 - 03:30 PM
Edited by Mighty Dodge Ram, 13 July 2019 - 03:31 PM.
1996 Dodge Ram 1500 4x4, lightly lifted, ARB bumper/Warn winch, BFG AT/KO2, Snugtop shell. SOLD! But not forgotten!
2002 Chevy 2500HD XC LB 6.0L 4X4, Leer Hi-Rise shell, completely stock...for now!
#3
Posted 13 July 2019 - 04:22 PM
The buy-in for a new or new-ish diesel truck will be quite high. More than an aux tank or larger than OE tank. In late model trucks I don't see the large MPG delta that diesels used to have over gassers. Since we had a diesel already and were still running low on fuel at times I went with a larger fuel tank.
Emissions controlled gasoline fuel tanks have more stringent Fed rules than diesel tanks so there aren't a lot of vendor options.
Downside to more fuel capacity is less truck capacity. Our larger tank holds nearly 400 lbs. worth of fuel when full.
Where does that road go?
#5
Posted 13 July 2019 - 06:42 PM
Is that how your wife gets in the truck
#6
Posted 13 July 2019 - 06:43 PM
Also Alaskan-less ... but fwiw ,I wanted diesel and picked a chassis that could accommodate a below the frame auxiliary fuel tank for the added range - that's where I put the money.
I'd suggest looking at cost and availability (per ntsqd) of your options.
Does your truck rear look similar to this ?
If so, I'd consider making a platform extending out the rear that supports 2 jerry cans. Maybe even spacing out the rear bumper to provide some protection (and a mount surface). Not ideal, esp with the LPG and toilet doors, but functional and relatively inexpensive, imo. Or I suppose perhaps could mount those flat type jerry cans to the upper rear wall. That might keep you going until a new truck.
If you're thinking replacement truck at this time anyway, then I'd say diesel if you can get a bigger or aux tank for that model (check first). And note that a delete may make a difference to the fuel consumption. Might have made a difference on vehicle wear and tear also ...
Edited by klahanie, 13 July 2019 - 06:46 PM.
#7
Posted 13 July 2019 - 07:16 PM
I had a custom built hitch rack "step" designed that had brackets to attach to the outside points of the hitch. I can easily carry two 5 gallon cans on it (weight is no issue, size is). We use it for water, but gas would work too. Will try to get a photo and upload it.
2005 Tundra 2013 Ocelot "Ridiculously comfortable"
2021 Tundra 2022 Cougar Shell Built Out "Even more ridiculously comfortable"
#8
Posted 13 July 2019 - 07:19 PM
BTW - we are in the market for a 3/4 ton gasser and an Alaskan, so am curious as to what size tank you have and gas mileage? If I could afford a newer diesel, might go that way, but too expensive for now. Thanks.
#9
Posted 13 July 2019 - 09:34 PM
#10
Posted 14 July 2019 - 03:39 AM
switched from a 2002 8.1L gas silverado to a 2006 diesel and am getting 2x the fuel economy. I also researched tank sizes and aftermarket options, and it is virtually impossible to get an aftermarket GAS tank. Diesel is no problem. My truck now has a 38 gal tank, and I can get a 62 gal aftermarket replacement that doesn't change the ground clearance.
VERY happy we made the switch to diesel.
