Bought this moderately used 2001 Grandby and am in the process of personalizing for my uses. First, hated the huge two-piece flip couch (old style, not the rollover couch). I needed a little more room for a cooler and to store my bike inside so...
2001 Grandby redo-upgrade-retrofit
Started by
oldhotrod
, Aug 19 2019 12:20 AM
9 replies to this topic
#1
Posted 19 August 2019 - 12:20 AM
#2
Posted 19 August 2019 - 12:29 AM
So ripped out the couch and thought about using the fwc dinette but it was wider than i wanted so made a smaller version. Then i tried making a table center piece but didn't like the result so...pulled some measurements and found a plastic table that could be made to fit...then attached a Lagun table arm and made a storage area at the back of the seat bases for the arm. And to keep the table top in place in bed configuration, it is "keyed" onto the rear cross piece.
#3
Posted 19 August 2019 - 12:37 AM
With interior roughed in, i mounted my solor panel. I wanted a set up that would be simple, light (no struts), easily removable for remote use or in storage. I chose the overland solar 160wt flex panel. But since the panel would be removable, i attached it first to a thin aluminum sheet with vhb tape and pop rivets, then built an aluminum frame. The front of the panel slides into a cross channel and the rear is attached with dzus 1/4 turn fasteners...
#4
Posted 19 August 2019 - 12:46 AM
I tried to order a lipo battery from a local company but kinda got the runaround so..The battle born battery was highly recommended by a kid on you tube so i contacted them and got a 50ahr battery that weighs a whopping 20lbs and is the size of a six pack...perfect and expandable. Plus their customer service was great, thanks Eric...he also recommended a 75/15 victron controller and i opted to go with bluetooth...i was quite nervous about set up but it was easy, went perfect and formatted it to the battle born recommendations...
#7
Posted 19 August 2019 - 01:48 AM
Very nice job oldhotrod. Like the new look.
Russ
Russ
#8
Posted 19 August 2019 - 02:04 AM
Thanks Russ, but in all honesty, it looks better in pictures as i am far from a craftsman but it was/is a fun project. I took several years of woodshop in jr and high school but that was decades ago...and rusty is an understatement but it is good enough for now
#9
Posted 19 August 2019 - 03:39 AM
Hi OHR
I think your too modest, how you went about it and your resources. Pre made table, plus used with a versatile table base, integrated storage pockets ( I hate stuff you move around and around) no special ordered cushions. The design of the chairs, or benches lightweight not the same old box design. I feel safe saying your instructor hit the mark good job it looks great.
Russ
Mortised hinges, magnetic lid latch, nice hand opening for lifting the lid.
Russ
Edited by CougarCouple, 19 August 2019 - 03:48 AM.
#10
Posted 19 August 2019 - 03:53 AM
Thanks Russ, now back away from the zoom tool ya stalker...[emoji16]
Edited by oldhotrod, 19 August 2019 - 03:54 AM.
