Building a table attached to camper Jacks
7 replies to this topic
#1 Aussiedor
Aussiedor
  • 36 posts
Posted 10 October 2019 - 05:14 AM
I did a very brief search for "table attached to camper jacks".  I did not come up with anything.   I thought this might be interesting for someone.  I purchased some folding brackets that lock when in the open position and attached them to the camper jacks using a worm gear clamp.  I'm not completely finished with the project yet but here are a few pics of what I've done so far.  I'll post a pic of my finished project when I'm done.
#2 Wandering On Wheels
Wandering On Wheels
    Newbie
  • Pip
  • 2 posts
  • LocationGrand Junction, Colorado
Posted 10 October 2019 - 04:05 PM
Great idea, where did you find those locking folding brackets? What are you thinking for the table top material?
#3 Aussiedor
Aussiedor
  • 36 posts
Posted 10 October 2019 - 04:44 PM
Brackets were purchased from the evil empire  :D  There's a good selection of them.  I purchased the 16" long brackets which will give me enough room for a nice size platform/table.  The "worm gear clamps" came from a local HomeDepot.  I'm sure you could also purchase them online.  I had no idea these clamps were called "worm gear clamps".  I had to drill a hole in the clamp and attach it to the bracket using a flathead screw.  The rubber around the jack is just a bicycle DH tube I had sitting around.  I'll do some trimming of the tube to clean up the look of it.  Not sure about the material for the table top will be.  I may also put a telescoping leg in the middle for extra support. That way I will be able to use a lighter wood for the table top.    I'm also planning on using bungie cords to keep the table tied down  when driving.
#4 Seattle Mitch
Seattle Mitch
  • 36 posts
Posted 10 October 2019 - 05:14 PM
As an alternative to the "evil empire", I've seen those brackets at Rockler Stores.
#5 Seattle Mitch
Seattle Mitch
  • 36 posts
Posted 10 October 2019 - 05:16 PM
I'd like to figure out a way to use them to attach a table to my Fleet, but I don't travel with the jacks attached.
#6 PaulT
PaulT
    Need gumbo
  • 1,720 posts
  • LocationHillsboro, Oregon
Posted 10 October 2019 - 11:18 PM
Should be easy to make some aluminum angle pieces to bolt to the jack brackets and bolt your table supports to the aluminum angle.
No need to be a machinst to make it. Just hold or clamp the aluminum angle to the jack bracket and use a spring loaded center punch to mark two or three jack bracket hole locations in the aluminum. Drill at the marked spots and use wing nuts/star knobs to hold the angle aluminum to the jack bracket's existing holes. No tools meeded to mount or remove the table.
I did this to hold a Harbor Freight flagpole to one of mine to support a ham antenna.
#7 RC Pilot Jim
RC Pilot Jim
  • 1,408 posts
  • LocationSan Diego Calif
Posted 10 October 2019 - 11:55 PM
Hi Aussie. Nice job.
Would you zoom out and give us a few more pictures showing the table attached to the legs?
Thanks.
Jim
2012 FWC Eagle Shell "bolted on"
2013 Tacoma Access cab V6 4WD
Our Basic Eagle/Fleet Shell Build
#8 Aussiedor
Aussiedor
  • 36 posts
Posted 15 October 2019 - 04:20 PM
Sorry, I kind of put this post up and i've not checked it for a couple days.  Anyway, I'm still trying to find a material for the table.  I'm thinking about a thin piece of stainless steel.  Something that will not rust or need maintenance.
