As soon as you turn off the gas, needle drops out of the green within seconds.
Edited by MikeMarkCA, 01 November 2019 - 05:04 PM.
Posted 01 November 2019 - 07:21 PM
Gauge is not indicative of a "propane Charge", just indicates whether the burner is lit or not.
Posted 01 November 2019 - 07:44 PM
If that is true then I guess maybe it is a problem of the flame going out..but it has auto ignition, wouldn’t it re-light?Gauge is not indicative of a "propane Charge", just indicates whether the burner is lit or not.
Edited by MikeMarkCA, 01 November 2019 - 07:47 PM.
Posted 01 November 2019 - 10:00 PM
Patrick
2015 FWC Hawk Flatbed
Posted 02 November 2019 - 02:59 AM
What model and year camper? You could have a auto relight system installed as to the sound you are hearing.
Posted 09 November 2019 - 11:15 PM
Can of compressed air works fine. Cleaning a burner is very simple to do and a dirty burner is a common problem. the auto ignition times out if the burner does not light or the flame is too weak. You can see the spark from the ignitor. It is also simple enough to remove the orifice and soak it in alcohol to clean it.
Steve
