6 volt batteries
13 replies to this topic
#1 Rhust
Rhust
  • 43 posts
Posted 25 November 2019 - 02:03 PM
I have a grandby on order and went with the dual 6 volt option. Does anyone know what batteries four wheel camper uses? Are they a good battery?
I also went with the 160 watt roof mounted solar panel and the 130 liter fridge?
Will I have enough power to run for up to a week at a time?
Thanks
#2 Norsman
Norsman
  • 39 posts
Posted 25 November 2019 - 02:54 PM
Dual 6 volt batteries with your solar setup .. you’ll rarely see a dip in your battery ( using primarily the fridge) if it can get a few hours of sun or driving per day.
My battery is topped off usually by 9am after running the furnace and fridge all night. I installed a Victron Bluetooth battery monitor so I could see exactly what is used and how many hours I have left at the current draw.
If you live in Phoenix or Las Vegas... we’ll I don’t know.
#3 Rhust
Rhust
  • 43 posts
Posted 25 November 2019 - 03:27 PM
Thanks for the reply. I live in Idaho, and in spring and fall I will be using the heater at night.
Are the 6 volt batteries it comes with good quality? Are they lithium, Amg or wet cell?
Thanks
#4 Norsman
Norsman
  • 39 posts
Posted 25 November 2019 - 03:35 PM
Thanks
Yes, the batteries are good AMG ones from Leoch.
Edited by Norsman, 25 November 2019 - 03:36 PM.
#5 camper rich
camper rich
  • 357 posts
Posted 25 November 2019 - 05:00 PM
I ordered our Grandby with the duel battery setup but bought my own 6 V Lifeline AGM golf cart batteries.  I also have a folding 100 W Renogy Solar panel to supplement my 160 in times of not enough sun.
Whether you have enough sun can vary depending on the campsite.  We have camped in some campgrounds in the PNW where there is very little sunlight due to the big trees, and on our trip to Alaska we had so much rain that we never saw the sun for 4 or 5 days at a time.  I carried our Honda 2200 generator for that trip and ended up using it several times.
#6 craig333
craig333
    Riley's Human
  • 8,018 posts
  • LocationSacramento
Posted 25 November 2019 - 05:21 PM
Under normal circumstances I'd say you should do fine. I have about 225ah worth of batteries. The other day (night) in very cold temps my heater ran probably every twenty minutes. Microwaved my breakfast burrito and still was only down to 93% S.O.C. It doesn't take much sunlight to recover 7%.  I should be able handle five days before I have to recharge. I haven't yet had to use the alternator to supplement solar but it should work well on say an Alaskan trip where I'd be driving a lot anyway.
The only thing I'd check is making sure your charge controller is outputting the correct voltages to keep your batteries happy.
#7 Bjammin
Bjammin
  • 34 posts
  • LocationPacific Northwest
Posted 25 November 2019 - 05:23 PM
The battery setup on our Hawk has been great.  We have the 160 Watt solar panel into to 6-volt AGM batteries which run the fridge, and heater.  We live in Oregon and can often get grey, dark skies, but so far we've only gotten a little worried.  It's true that on dark winter days we wake up with the batteries below 12 volts, but even with grey skies, they perk up pretty quickly in the morning.
#8 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,960 posts
  • LocationCalgary, Alberta
Posted 25 November 2019 - 06:35 PM
Microwave?  Now that's glamping!   :D
#9 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,960 posts
Posted 25 November 2019 - 06:37 PM
Below 12v with no load on them?  That would put you at well below 50% SOC which is not good to do on a regular basis as it greatly decreases battery life.  For reference, with no load 12.2V is about 50%.
#10 craig333
craig333
    Riley's Human
  • 8,018 posts
Posted 25 November 2019 - 07:37 PM
Yeah, not good. I wake up with 12.8 volts on my batteries.
The microwave is cheap 600 watt thing I bought years ago. How its stood up to the abuse I have no idea.
