who uses Fog lights? / Hella 500 / OEM connector->F350
#1
Posted 28 November 2019 - 05:20 AM
#2
Posted 28 November 2019 - 08:04 AM
#3
Posted 28 November 2019 - 01:41 PM
I got a set of Baja designs wide cornering lights. They had a mount and wiring adapter to plug and play in my F-150.
Really awesome lights, they light up the ditches and around the curves here in East TN. I’ve only had one person comment about how bright they are, no one has high beamed me
2021 F350 SCLB
FWC Grandby,
EBY Big Country Flatbed, Buckstop Outback front Bumper
Gabby (GSP), Sox (GSP/American Bulldog)
2011 F150 SCLB HDPP
#4
Posted 28 November 2019 - 03:37 PM
I always have fog lights on cars and trucks.
Low height wide spread works best. Best to wire with the stock harness because then they will work properly and when high beams come on fogs go off...(that's the law in many states I believe)
Edited by knoxswift, 28 November 2019 - 03:40 PM.
#5
Posted 28 November 2019 - 04:29 PM
They don't cut through the kind of fog we get here. Best you can hope for is lighting underneath the fog. They do help people see you coming better. I find them most useful in rainy conditions, kind of takes the blackness off the road. Offroad they do act as ditch lights.
#6
Posted 28 November 2019 - 05:04 PM
I have them, but I don't think I'd miss them if they were gone. They don't help with the "tule fog" we have in N. California. If they were (much) brighter pointed outward a little more they would work as cornering lights. I have used them at night in a campground to prevent shining my headlights into everyone's camp.
#7
Posted 28 November 2019 - 06:12 PM
When I retrofitted new headlight into my 40 yr old ones I went with Hella extreme yellow H4 bulbs. Living in the rainy Pacific Northwest I find they make a good difference.
Another good source of bulbs/lights is https://www.rallylights.com/
#8
Posted 28 November 2019 - 06:35 PM
I never thought they did much good. I have them on 3 vehicles and never use them.
#9
Posted 28 November 2019 - 07:39 PM
I find most "modern" cars don't let you turn off enough of the other lights to make them super useful. If you can, wire up your lights so that when the fogs are on, ALL of your other front facing lights are off... otherwise the glare from DRL or low-beams make the fogs less useful.
/rant on
The stock "fog lights" on most vehicles aren't really fog lights... more like extra annoying un-focused scattershot lights...
/rant off
#10
Posted 28 November 2019 - 11:01 PM
/rant on
/rant off
^ why I try my best not to drive at night. Winter commute is bad enough with everyone and his dog running fogs 24/7 in addition to their new vehicle or retro fitted super brites. ugh.
LA, for the 100 bucks I'd prob get them. You only have to really need them once and they'd be worth it. One gotcha with your plug and play idea might be that the oem fogs are a much lower wattage and the wiring, harness and/or ECM (or which ever electronic brain) might not like the upsize.
Also, the for very specific Ford questions, like part nums, you might want to also check with fordtruckenthusiasts. Lots of folks on there with newer SD trucks and the $ to mod them.
EDIT to add a bit
Edited by klahanie, 28 November 2019 - 11:29 PM.
